Old 07-02-2014, 11:51 PM   #1
SLC_BRZ
Drives: 2013 WRB BRZ
Wheels on stock tires
So noob question here, my stock tires are still practically brand new so I want to run wheels that will fit them. So on that note can 17x8 only fit or is there a little wiggle room like 17x7 to 17x8.25?
SLC_BRZ is offline   Reply With Quote
Old 07-03-2014, 03:41 AM   #2
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Stock 215/45/17 tires are on 17x7 OEM wheels. You can put them on 17x8 aftermarket wheels if you like but most of us wanted to get some higher performance tires.
mit_peid is offline   Reply With Quote
Old 07-03-2014, 12:07 PM   #3
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Sell the stock tires. They aren't the worst tire, and someone might still want them, plus I see people on here looking for used tires that they can tear up drifting. If they're brand new you might be able to get a few hundred out of them to take the sting off the purchase of new tires.
Nevermore is offline   Reply With Quote
Old 07-03-2014, 08:11 PM   #4
tomkozski
Drives: 2017 WRB BRZ w/ PP
You can always go to tirerack and look up the specs. The rim width range for the Primacy's is 7-8 inches, meaning they shouldn't be mounted on rims wider than 8 inches. While some stretch tires for looks, the tire isn't designed for that and over-stretching becomes a safety issue.
The Primacy's are good tires (tirerack lists them as "Grand Touring" tires), and if you plan to autocross or anything like that they're good at teaching you the limits of the car and helping you hone your skills as a driver. I've gone autocrossing on my stock tires, and have posted times better than drivers in FR-Ss/BRZs with upgraded suspensions and tires.
tomkozski is offline   Reply With Quote
Old 07-03-2014, 08:29 PM   #5
dabocx
dabocx's Avatar
Drives: Scion FRS
I put them on a 8 inch but it was already too stretched for my taste. Id sell and pick up something a bit better
dabocx is offline   Reply With Quote
Old 07-03-2014, 09:00 PM   #6
gramicci101
Off Topic
I've seen people put 215's on 9.5's in the aggressive wheel fitment thread. Where there's a will, there's a way.
Old 07-03-2014, 09:44 PM   #7
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
spending money on rims before tires says a lot. Are you prioritizing on cosmetics? My recommendation is buy tires, sell the stock ones and look for some used wheels. Just my opinion.
Old 07-03-2014, 10:49 PM   #8
Boxer486
Drives: small
I don't think that's really fair. The stock tires are fun for low speed stuff. If they were cheaper I'd probably keep using them for narrow backup rain tires which can also hoon and get good mpg.
Boxer486 is offline   Reply With Quote
Old 07-04-2014, 12:56 AM   #9
SLC_BRZ
Thanks for the help guys I appreciate it, i guess maybe I am prioritizing on cosmetics I don't track my car yet so having a high performance tire isn't way high on my priority list however that is subject to change, I'll cross that bridge when I get there.
Old 07-04-2014, 01:08 AM   #10
SLC_BRZ
The wheels I'm looking at are 17x8.25 is that just too much for stock tires?
Old 07-04-2014, 09:27 AM   #11
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
If I were you I'd save up my money to buy both new wheels and tires at the same time. That way you will have exactly what you want in the way of wheels without having to make any compromises. Why spend a lot of money on wheels that you may end up wanting to replace when the stock tires wear out.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 07-04-2014, 01:11 PM   #12
Reaper
Reaper's Avatar
Drives: violent
the stock tires are very fun and great at teaching you. Im just trying to be the voice of reason and play the advocate. Wheels alone is a lot of money to throw at the car with no real gain when keeping stock tires on.
The Following User Says Thank You to Reaper For This Useful Post:
Boxer486 (07-04-2014)
Old 07-04-2014, 02:50 PM   #13
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Anyone have some picture of how they look stretched on 8 or 8.25
Old 07-04-2014, 05:20 PM   #14
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I have them on 8 inch wide OZ wheels and they are fine. The curb guard still sticks out past the wheel. I'm not a fan of stretch but they are great tires to learn limits on. You could probably put them on an 8.5 if the tire shop was willing (but 8 is actually still in Michelin spec)
Khyron686 is offline   Reply With Quote
stock brz wheels and tires $400 kingkai23 NY / NJ / CT / PA 3 05-17-2014 07:07 AM
Stock Wheels & Tires tintumz22 Wheels and Tires 2 06-15-2013 06:10 AM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 12:07 PM
FS: STOCK FRS WHEELS AND TIRES stevieb0y Wheels and Tires 4 03-11-2013 09:29 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 11:26 PM
