Drives: 1998 Ford ZX2
Noise while slowing to a stop
I have been hearing this faint sound every time I slow to a halt. Sounds like some pump/fan spooling up and then stopping. Lasts for a few seconds. Any idea what it could be?
I will try to capture it on video/audio sometime today evening. (2013 BRZ Limited) |
#2 | |
Drives: 2014 BRZ black premium
http://www.ft86club.com/forums/showthread.php?t=68912 |
Are you putting it into first as you're slowing down with the clutch in? If so, what you're probably hearing is the faint whine of the gears as the synchros force the transmission input shaft up to a higher speed. (In 1st, the input shaft is at a shorter ratio to the output shaft, thus engaging 1st at a given speed requires a higher rpm).
Or in other words, it's normal, nothing to be concerned about. |
#4 | ||
Maybe it is the A/C compressor running for a really short time? I wasn't running the A/C this morning and I heard nothing. |
Drives: SWP BRZ Limited
Does it sound like a chuttering/puffing sound sort of?
I've noticed when I have the AC on that when I come to a stop sometimes my revs drop to 500ish rpm, then flare up to 850ish before settling back down to a normal idle. With the windows down and no radio on, it sounds strange. |
Do you have a manual transmission? If so I'd guess flywheel/clutch rattle.
http://www.ft86club.com/forums/showp...0&postcount=20 |
Drives: Raven Scion FR-S
Air condition fan turning on? Could be you hear it bc your slowing down. It goes on and off
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
Drives: 2014 FRS Raven. 2011 sti red (gone)
If manual - flywheel
If auto - an automatic transmission being an automatic |
I did some more testing and this is it. I think I didn't hear it before because I got the car in fall of last year and the last couple of weeks are the first time I have extensively used the A/C.
| 2nd gear grind while slowing down NO clutch | Muskokan | Issues | Warranty | Recalls / TSB | 12 | 07-18-2017 01:35 PM |
| Ratting when slowing down | aghuman | Issues | Warranty | Recalls / TSB | 9 | 03-23-2014 03:08 AM |
| Hearing a ticking noise when slowing down to a stop with fan and/or AC on | itisthumper | Issues | Warranty | Recalls / TSB | 1 | 07-18-2013 09:34 PM |
| MT, neutral 15-10mph slowing, ratcheting noise | bcj | Engine, Exhaust, Transmission | 7 | 04-18-2013 12:33 AM |
| Automatic Shuddering when slowing to stop | Craig | Issues | Warranty | Recalls / TSB | 0 | 11-14-2012 06:40 PM |
