Old 06-26-2014, 11:35 PM   #1
Captain Stark
Captain Stark's Avatar
Drives: Subaru BRZ Limited, Galaxy Blue
Valenti Reverse Light Installation Issues
So, I'm probably some kind of idiot, but I can't seem to remove the stock reverse light. Mostly the part of getting it out of the housing. I removed the bolts on top and the clips on the side, there just doesn't seem to be a big enough hole to actually get the light out (the muffler is in the way).
I'm sure there is some sort of way to do it, I just can't seem to figure it out myself.
Help would be much appreciated.
Captain Stark is offline   Reply With Quote
Old 06-26-2014, 11:46 PM   #2
Wizardhat
Wizardhat's Avatar
Drives: 2013 FRS
Release the lower bumper clips that secure the lower part of the bumper to the car. I cant remember how many there are, 5 or 6. They are plastic clips come out easily. Then you can pull down the lower part of the bumper and have room to work. It gives without problem, dont have to pull hard. There is a clip in the center of the backup light that is hanging you up. Its on top I recall. You can see where your new one has the spot for that clip. I broke the stock one getting it off. Oh well, was not planning on reusing it.
Wizardhat is offline   Reply With Quote
Old 06-27-2014, 05:16 AM   #3
Captain Stark
Are these the clips that are on the bottom, near the wheel wells? And I thought I broke the clip on the light, but it was just fine.
Old 06-27-2014, 06:05 AM   #4
nphillip
nphillip's Avatar
Will this help?
[ame]http://youtu.be/0jrFASjxwWQ[/ame]
nphillip is offline   Reply With Quote
Old 06-27-2014, 10:25 AM   #5
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
This was a bit of a pain for me as well (worse because I have the diffuser). Right in the middle of the underside of the bumper kind of comes in at a point where there's a bit more clearance then anywhere else along there. You should be able to, using a bit of force but not too much, to push/warp the bumper away from the muffler and get just enough space to get the reverse light out by feeding it through that space length-wise. Does that make sense?
If you have the diffuser, it's a lot easier if you remove that first, if you can (I couldn't). The good news is, once you get the old one out, the new one is a lot thinner and will fit through the space without any issues. I can try and take a picture of the space i'm referring to if I'm explaining this terribly.
Pwolf is offline   Reply With Quote
Old 06-27-2014, 12:21 PM   #6
Wizardhat
Wizardhat's Avatar
Drives: 2013 FRS
They are the round pins holding the lower bumper to some plastic brackets. Just look at the bumper edges where you are working and you see them. They just pry out with a screwdriver. Same type of pins that are used for securing the the front bumper underneath the car.
Old 06-28-2014, 08:35 PM   #7
Captain Stark
Got it!! Thank you Wizardhat and Pwolf, your suggestions helped a lot. I removed just two of the clips on the bottom, and it freed up enough space to slide the old light out, and the new one in.
And nphillip, I watched that video, it's how I got around to getting it unbolted from the car, but in their video, they have the muffler removed. That was waay to much work to just put in the taillight, thank's for the suggestion though!
Old 06-29-2014, 10:57 PM   #8
Wizardhat
Wizardhat's Avatar
Drives: 2013 FRS
Alright. Enjoy!
Old 06-30-2014, 01:16 AM   #9
Pwolf
Pwolf's Avatar
Great to hear! Enjoy :P
Old 07-22-2014, 09:48 PM   #10
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
I have the Valenti reverse light thing and Tom's tails.
The instructions from Modbargains says light blue wir to dark blue wire from OEM tail harness, but my harness has red/black light green and yellow(?)
where does the light blue wire splice into???
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
Old 07-23-2014, 11:07 AM   #11
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
I just spoke to a local BRZ owner with the Valenti reverse light and he gave me this advice for the basic wiring to get the red portions lighting up with running lights, etc.
"Valenti light blue [wire] tapped to red wire in [OEM] tails harness. Valenti red [wire] tapped to light green wire in [OEM] tails harness. That should give you the basic functionality"
Thanks, @Simon99
Old 07-23-2014, 11:10 AM   #12
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
If anyone can figure a way so that the triangle flashes during daytime (i.e. without the parking lights being on) I would be grateful ! But the way I've come to understand it is that the small red wire from the Valenti is just a trigger that makes the triangle flash when the brakes are depressed AS LONG as current is already sent to thr triangle from the Valenti light blue wire..
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 07-23-2014, 05:31 PM   #13
Wizardhat
Wizardhat's Avatar
Drives: 2013 FRS
You are correct in that the small red wire just triggers the already on triangle light to flash. One would have to open up the assembly itself and mess with the interior wiring to find a way to power the V bar and triangle like DRL's if they wanted the flashing light without the parking lights on during the day. The pictures I have seen of the circuit board inside do not look promising for finding a way to achieve your desire here.
Old 07-23-2014, 05:35 PM   #14
Simon99
Simon99's Avatar
This is the tutorial i would need to follow
Replace the DOT in the link
http://www.86forumsDOTcom.au/index.p...ion-light-mod/
installation, reverse light, valenti
Input needed from those with Valenti rear fog/reverse light Simon99 Cosmetic Modification (Interior/Exterior/Lighting) 7 08-21-2015 09:43 AM
Place where I can have my Valenti reverse light rewired? ModalSoul37 Northern California 6 06-09-2014 12:54 AM
Valenti rear bumper/reverse light question ft86me Cosmetic Modification (Interior/Exterior/Lighting) 1 01-04-2014 02:22 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
