Old 06-26-2014, 02:55 PM   #1
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
FT86SpeedFactory Catted UEL Review (long overdue)
This is my review of the headers.
First Impressions in Box
The box was whatever, packaging was nice and tight to prevent damage. Taking the headers out, it looked nice. The flanges were straight and it looked as I expected it to look so there was no let down due to "enhanced" images.
Came with all the necessary hardware. And let's not forget the magical laffy taffy!
Install
Couldn't wait to install it so i jacked up the car and immediately began to install.
it was lighter than stock obviously
02 sensors gave me some trouble but eventually got them out.
The rest of the install was just a simple bolt on. Connected to my Perrin OP no problem. NO EXHAUST LEAKS
Driving Impressions
at first, a big rattling sound occured and I knew it wasn't normal so up went the car again. found out that the skid plate gave me some clearance issues so i had to "modify" if so that it wouldn't rattle (circled it in red). One of the runners made contact with the plate so every time i accelerated, it vibrated like something was going to explode. I just installed it back without putting in the tabs and it gave me a few more mm of clearance and no problem since.
driving it was pretty nice. more midrange torque. and a MUCH better sound. sounds like a hybrid between a Subie and a pissed off Evo combined in my opinion. MPG was also surprisingly better backed by my fuelly. I can also climb hills on the freeway and other streets no problem on 6th gear now. That's right... 6th. I don't have to downshift to climb anymore. (depends on speed... but you get the point).
my butt dyno doesn't lie!
No drone with my exhaust set up. Civil when I'm cruising on the freeway and the streets, but ROARS when I step on it.
the rumble starts from low end up to about 4k-4.5k rpms, and at that point it starts to trail off and sound more Equal Length (hence the pissed off Evo). The rumble is also more prominent the more you step on the throttle (obviously).
Overall pretty happy with my purchase. Let's not forget the best part...
No SMELL!
- Installed since 4/14/14 (since then, I have logged 6,727 miles and no major issues)
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 06-26-2014, 02:55 PM   #2
Tylub
Tylub's Avatar
videos
stationary and slow drive by
[ame="https://www.youtube.com/watch?v=VCnCqqib-J8"]Ft86speedfactory Catted UEL - YouTube[/ame]
drive bys in various RPM ranges
[ame="https://www.youtube.com/watch?v=vDEJoqnf1no"]Ft86speedfactory Catted UEL drive by - YouTube[/ame]
POV from exhaust: city driving and highway pulls
[ame="https://www.youtube.com/watch?v=s-GZCT7WWHM"]Ft86SpeedFactory Catted UEL - YouTube[/ame]
In-Cabin
[ame="https://www.youtube.com/watch?v=3qkVlqn8f8w"]Ft86speedfactory Catted UEL in-cabin - YouTube[/ame]
instagram @Tylub
Old 06-26-2014, 02:59 PM   #3
bigdawg86
How long was this install? I'm looking to doing this and and overpipe swap as my first modification... Continue overtime!
bigdawg86 is offline   Reply With Quote
Old 06-26-2014, 03:03 PM   #4
Tylub
Tylub's Avatar
about 2 hours of tinkering, not too bad although I can probably do this in less time now that I know what I'm doing
do it!
instagram @Tylub
Old 06-26-2014, 03:05 PM   #5
husker741
Great review. I never had a problem with the skid plate but I'm glad you got it fixed. I love my sound and agree with your impressions. It's a great header!
I have a very similar setup. If anyone wants to hear how mine sounds, just click my build thread link on my signature and the first post has some videos.
husker741 is offline   Reply With Quote
Old 06-26-2014, 05:39 PM   #6
akahenry
akahenry's Avatar
Drives: '18 STi
I feel like the best way to get the rumble out of these catted headers is for the front pipe to be catless and, or resonated/unresonated, along with some aftermarket cat backs.
akahenry is offline   Reply With Quote
Old 06-26-2014, 05:42 PM   #7
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
I'm running the header, a catted unresonated Nameless fp/op and a Perrin Resonated catback and the rumble is very clear with my car
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 06-26-2014, 06:00 PM   #8
FR-S Matt
That does sound pretty EL at higher RPM's. Probably because of fitting the cat and changing the runners a bit?
Sounds really good. Found a good balance of loudness. The only solution to removing some of the in cabin loudness is a helmholtz resonator in the front pipe.
Old 06-26-2014, 06:18 PM   #9
Tylub
Tylub's Avatar
Because the runners aren't as extremely unequal as say, jdl, it smooths out in the upper RPMs. In the video, it was just a frequency that the mic picked up. Normal driving you barely hear it. The set up is actually quieter than an evo3 catback. Once you step on it, it is a lot louder as expected, but the nice part is that it doesn't drone or hurt your ears under WOT(while equating the volume of a perrin headerback (catted fp non res) but yes, adding a helmholtz resonator would be nice
instagram @Tylub
Old 06-26-2014, 06:20 PM   #10
Tylub
Tylub's Avatar
It's just the design of the headers, and once you start going catless/nonres then it may get raspy.
instagram @Tylub
Old 06-27-2014, 02:58 AM   #11
akahenry
akahenry's Avatar
Drives: '18 STi
you still havent posted an exterior sound clip of your setup, how dare you.
Old 06-27-2014, 03:28 AM   #12
s2d4
s2d4's Avatar
Is this stock CBE?
EDIT: NVM, just saw ARK DTS
Old 06-27-2014, 10:56 PM   #13
Jamesbrz
Drives: White BRZ
Have you had the engine light come on with this manifold, or did you get a tune?
Jamesbrz is offline   Reply With Quote
Old 06-28-2014, 03:10 AM   #14
MagicBobert
MagicBobert's Avatar
Drives: 2014 WRB BRZ Limited
Huh, I have a buzzing/rattling with my OpenFlash header and I haven't been able to pinpoint it yet. I never thought about the skid pan. I'll have to take a look at it. Thanks!
MagicBobert is offline   Reply With Quote
FT86Speedfactory Catted UEL Header review! (Photos and Videos) fender9530 Engine, Exhaust, Transmission 72 06-20-2019 11:16 AM
Why is nobody making catted UEL headers except ft86speedfactory? Venator Engine, Exhaust, Transmission 88 07-21-2014 09:06 AM
FBM long overdue review pmccut User/Vendor/Sponsor Reviews, Feedback, Comments 0 02-16-2014 03:55 AM
Ft86SpeedFactory Review ChandlerSwyng User/Vendor/Sponsor Reviews, Feedback, Comments 9 09-30-2013 10:09 PM
dual injection is just a long overdue solution to carbon build up? Hasjwandje Engine, Exhaust, Transmission 19 11-08-2011 05:53 PM
