Old 06-23-2014, 05:15 AM   #1
djmm
djmm's Avatar
Drives: toyota
How do you clean underside of car and its engine?
I've owned the car for almost 3 months and have done several car washes by myself. I've never cleaned the engine and the underneath of the car though.
Do you guys clean them yourself? If so how do you do it?
I was thinking to drop by carwash place and ask them to clean the underneath of the car only. But I also wonder how often I should do this if I don't really go off road and only use the car for city driving.
djmm is offline   Reply With Quote
Old 06-23-2014, 05:20 AM   #2
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Hum... and I wonder if it's a good idea to take the fiber underpanels of to clean behind them? About the engine, I've heard compressed air is a good way to go...
Harvey is offline   Reply With Quote
Old 06-23-2014, 05:38 AM   #3
Karl07
Drives: 2012 86 GTS - Storm Black
Because of the under panels this engine bay doesn't seem to get too dirty, thankfully.
However, when I cleaned the engine I do everything by hand. Start at the high point and work my way lower.
Now that I have a vented bonnet, however...I don't think I'll even bother too often.
Karl07 is offline   Reply With Quote
Old 06-23-2014, 06:25 AM   #4
Die$eL
Die$eL's Avatar
Drives: Toyota MR2 Spyder Turbo
For the engine bay, I have a high pressure washer at home and use that (with the car idling)
Then i wipe it all with a chamois
For under the car, I take it to a friend's workshop and put it on the ramp. Then i grab a bucket, some warm water and a cloth and get to work. For stubborn dirt i use engine de-greaser.
Die$eL is offline   Reply With Quote
Old 06-23-2014, 07:48 AM   #5
djmm
djmm's Avatar
Drives: toyota
Speaking of car cleaning, you know the front air grille, I never sprayed directly into the grille worrying that I might get water in places which are not supposed to be. Always sprayed water from an angle from the top of the grille.
Old 06-23-2014, 07:50 AM   #6
Karl07
I dont think you have any worry about that. Basically just getting water on the radiator.
I don't know if I would spray directly with a full pressure blast from a high pressure hose...maybe bend some fins...
Old 06-23-2014, 08:10 AM   #7
djmm
djmm's Avatar
Drives: toyota
Our water pressure at the apartment is quite strong - but I think it will dislodged my hose before it can create strong enough pressure to damage the car. But then again the of the car is so thin, I'm afraid it got bent from strong water pressure.
Old 06-23-2014, 10:38 AM   #8
Odd
Odd's Avatar
Drives: DGM BRZ
Odd is offline   Reply With Quote
The Following User Says Thank You to Odd For This Useful Post:
Jyn (06-23-2014)
Old 06-23-2014, 10:59 AM   #9
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
I do this.
[ame="https://www.youtube.com/watch?v=LESRJrB1L5I&feature=kp"]https://www.youtube.com/watch?v=LESRJrB1L5I&feature=kp[/ame]
jadewbj is offline   Reply With Quote
The Following 2 Users Say Thank You to jadewbj For This Useful Post:
CAMBAM_6 (06-23-2014), racecat (06-26-2014)
Old 06-23-2014, 11:02 AM   #10
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
this is my favorite tool to use when cleaning the engine, really gets into some tight spaces
http://www.chemicalguys.com/Chemical..._p/acc_s90.htm
i also use it on the wheels,
on my old car, i would use it from time to time when i had the wheels off to clean suspension parts ect ect
Old 06-23-2014, 11:38 AM   #11
Harvey
High pressure water in the engine bay, I've always wondered if that was a good idea. I have no doubt it clean well (with some solvent), but what are the risks of getting water and muck in places where it shouldn't be?
Also, why have the car idling?
Old 06-23-2014, 12:30 PM   #12
stevesnj
stevesnj's Avatar
Originally Posted by Odd View Post
Don't use simple green, could effect and promote corrosion if left on for more than 10 minutes. I believe Simple Green HD (purple) is formulated more for aluminum. Or this http://industrial.simplegreen.com/in...ation_zone.php
Old 06-24-2014, 08:16 AM   #13
Die$eL
Die$eL's Avatar
i never had any issues washing with a high pressure cleaner. Just dont spray the air intake opening and avoid spraying the electrical boxes.
rubber belts swell with water and start making a noise. I keep the engine running to immediately throw off water from the belts and other moving components.
For cars with a distributor rather cover it with a plastic. I've never washed the engine of a car with a carb but i doubt i would have it idling when washing the engine.
Old 06-25-2014, 12:45 AM   #14
torqdork
torqdork's Avatar
Drives: RV-7
For the undercarriage and >$10, I rinse the same way as my FJ Cruiser after a beach run. Move it after 15 minutes per corner and you're good to go.
http://www.homedepot.com/b/Outdoors-...tialmax&NCNI-5
torqdork is offline   Reply With Quote
MotoIQ: Tech Look at FR-S Underside - Suspension, Chassis, Brakes, Differential oneday Suspension | Chassis | Brakes -- Sponsored by 949 Racing 93 09-22-2017 10:47 AM
best way to clean up engine bay and vortech pipes? Frs32907 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 05-11-2014 10:13 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Scraped The Underside Of My Front Bumper Therightmike Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 24 08-30-2013 07:54 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
