Old 06-20-2014, 11:45 AM   #1
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
You want a tS dash in LHD? No Problem
So some may not want to wait for the 2015 model BRZ to get the dash. I did not want to wait and I found some good ole 3M vinyl on ebay and went to work. The color is almost spot on.
This is the type of 3M ordered
[ame="http://www.amazon.com/3M-Scotchprint-Carbon-Fiber-Anthracite/dp/B00597WDN6"]Amazon.com: 3M Scotchprint 1080 Carbon Fiber Vinyl Flex Wrap Anthracite CF201 60"x12": Automotive[/ame]
Take your dash pieces out and grab your heat gun. Go to town and it will look like this.
I added a little touch of my own with a small subtle STi decal in the bottom right.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
The Following 5 Users Say Thank You to Khazzy For This Useful Post:
8R6 (06-20-2014), bedabi (11-15-2014), BRZNutt (06-25-2014), Cjymiller (06-24-2014), SkAsphalt (06-24-2014)
Old 06-20-2014, 02:23 PM   #2
aaronglass
Artist / Audio Nerd
aaronglass's Avatar
Drives: 2014 Subaru BRZ, Limited
Looks so good! How did you get such a smooth wrap? I'll attempt this today.
aaronglass is offline   Reply With Quote
Old 06-20-2014, 05:37 PM   #3
Khazzy
Khazzy's Avatar
USE A TON of patience. Do no rush the job at all. Basically stick the flat surfaces first then work your way around. When you get a wrinkle, pop out the hair dryer (heat gun preferred) and do a couple passes and you will see the wrap move and shrink from the heat. Pull gently out and press on the curves. You will get the hang of it no problem after the first corner pull.
Old 06-20-2014, 05:38 PM   #4
qoncept
qoncept's Avatar
I wrapped mine twice and I can't get the stereo bezel right. Wrinkly in the bottom left corner and then the corners around the HU both pull out once it gets hot in the car. Once with a hair dryer, once with a powerful heat gun.
qoncept is offline   Reply With Quote
Old 06-24-2014, 04:57 AM   #5
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
I'm thinking about doing this with a red color vinyl though (similar to the ones seen in BMWs). Any tips on how to cut the vinyl to make it so smooth?
l0aded is offline   Reply With Quote
Old 06-24-2014, 07:45 AM   #6
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Hey I see you're in Bellevue... I got my degree's through Bellevue University online and loved the experience! Most military friendly school I came across!
Subaru STI :
The Following User Says Thank You to Kimsey47 For This Useful Post:
Khazzy (06-24-2014)
Old 06-24-2014, 11:48 AM   #7
Khazzy
Khazzy's Avatar
Updated pics.
The Following User Says Thank You to Khazzy For This Useful Post:
chaoskaze (10-30-2014)
Old 06-24-2014, 12:11 PM   #8
qoncept
qoncept's Avatar
Cutting is the easy part. Make your cuts around the back where you can't see and they don't really matter,
The Following User Says Thank You to qoncept For This Useful Post:
l0aded (06-24-2014)
Old 06-24-2014, 01:12 PM   #9
Khazzy
Khazzy's Avatar
Exactly. Stretch the visible area and then when you pull it to the back then make your cuts. When you see it wrinkle, pull back up, heat, then stretch again. Work from one corner to the other and you will be good. Just be patient with it, it took me almost 2 hours for everything. Do not rush the job and when you see a bubble, pull up, press and heat.
The Following 3 Users Say Thank You to Khazzy For This Useful Post:
BRZNutt (06-25-2014), l0aded (06-24-2014), soundman98 (07-01-2014)
WTT: My FR-S black dash trim pieces for your BRZ silver dash trim pieces. Tim_Asphalt_FRS Interior Parts (Incl. Lighting) 1 05-13-2013 06:25 PM
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 12:43 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
Problem! axss Scion FR-S / Toyota 86 GT86 General Forum 32 11-24-2012 02:31 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
