Old 04-28-2014, 10:17 PM   #1
EN2_Squirrel
EN2_Squirrel's Avatar
Question High Compression pistons
I was searching and couldn't find if anyone makes high compression pistons. I am looking into a high compression N/A build. Is 250whp too unreasonable? Looking into camshaft if rules allow? Street Modified scca solo rules
EN2_Squirrel is offline   Reply With Quote
Old 04-28-2014, 10:26 PM   #2
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Hmm...you're starting with 12.5:1. I suppose you can try 13:1 or maybe 13.2:1 and keep it together, but it is going to be a lot of expense for rather smaller gains. I think with some cams, intake manifold, big runner header and exhaust--you can shift some of the power band from down low to up top and get to 250. But the CR is a very small component of that when starting with a 12.5:1. We tune World Challenge cars with 2.5l mazda motors that start out as 9.5:1. Going to 11:1 gets us less than 20 hp generally. And that's a more substantial jump.
Xero-Limit is offline   Reply With Quote
Old 04-29-2014, 04:21 PM   #3
Panda Mao
Panda Mao's Avatar
Drives: 2014 Scion FRS
the fa20 motor is already high compression from the factory in my opinion 12.5:1 is insanely high on stock motor but considering the technology we currently have and with direct injection it all makes sense oem wise.
If this was an older motor (maybe 10 or 20 years ago) to even reach 12.5:1 from let say 8.5:1 is a huge jump not to mention other things that have to be addressed like timing and fuel as well as physical mechanical things like valves from hitting the piston crowns etc etc. So ya even if it was possible to go higher than the stock compression it would be financially pointless for probably less than 5 hp gained.
Panda Mao is offline   Reply With Quote
Old 04-29-2014, 04:45 PM   #4
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
JE makes some 13.5 cr
In 86 and 87mm bore size
https://www.jepistons.com/Catalogs/S...baru/fa20.aspx
marcoaferrer is offline   Reply With Quote
Old 04-29-2014, 04:52 PM   #5
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
Just make sure you mod everything accordingly, ESPECIALLY cooling. As mentioned, this engine is pretty high comp OEM so going up even more you'll really need to be careful as tuning will be knife's edge if you don't do all the supporting mods.
We can get custom pistons made from CP or JE, CP is a great choice
Jason@DSG is offline   Reply With Quote
Old 04-29-2014, 04:53 PM   #6
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Getting that NA from the FA20? Yeah, I think that's unreasonable even with higher compression. If you go much higher and run advanced enough timing to get to 250, I speculate that you'll be pushing the knock boundaries of even race gas, if not exceeding the physical capabilities of the motor and thus blow it up in the attempt.
Now, if they come out with a H6 FA30, then 250 NA would be completely doable, I think.
^GT5 Replay Photo Mode^
Old 04-29-2014, 04:57 PM   #7
marcoaferrer
I think 250 is deff doable with people breaking 200whp with just intake/full exhaust and e85.
If you can get your hands on a stroker kit some cams maybe the crawford power blocks and some 13.5 pistons I dont think its too crazy of an idea
You just need to be prepared to run e85
Old 04-29-2014, 05:49 PM   #8
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
One can only dream.
Old 04-29-2014, 05:56 PM   #9
SirBrass
SirBrass's Avatar
Originally Posted by tahdizzle View Post
One can only dream.
I'm dreaming of an FA30 H6 hybrid port/direct injection motor in the midengine.
Subaru shall call the car: BMZ
And we shall love it, and drive it, and race it, and drift it and call it George
Old 04-29-2014, 06:02 PM   #10
michael_king
Drives:
If you want 250HP and to run in SM why not just go twin-screw w/ 70mm pulley for the same result?
michael_king is offline   Reply With Quote
Old 04-29-2014, 06:47 PM   #11
MAPerformance
Drives: Asphalt FRS
Follow this thread
http://www.ft86club.com/forums/showthread.php?t=63901
MAPerformance is offline   Reply With Quote
Old 04-29-2014, 07:20 PM   #12
EN2_Squirrel
I want to do this car N/A. Seems like it would be more fun that way. when drove @whataboutbob 's car there still seemed lag even with the innovate kit. the torque came out of nowhere and then i was backwards. still alot of fun though. the torque wont come out of nowhere(if anywhere) this way.
Old 04-29-2014, 07:22 PM   #13
tahdizzle
So elite I'm 1338
Because 250 whp NA twin > 250 whp blown twin.
Old 04-29-2014, 08:19 PM   #14
Jason@DSG
Jason@DSG's Avatar
E85 or race fuel will be possible but it requires a full engine build especially if you go up in compression, and major cooling and a REALLY good tuner
Low Compression Pistons vs New Shortblock SilverTipp Forced Induction 11 04-11-2014 05:45 PM
Why aren't some concerned about putting a turbo on a high compression motor? dave77 Forced Induction 50 01-13-2014 02:22 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
High compression engine fuel requirements Ben_G Engine, Exhaust, Transmission 3 01-16-2013 11:44 AM
queston about low compression pistons on stock ECU clayrush Engine, Exhaust, Transmission 1 12-03-2012 11:11 PM
