Old 06-12-2014, 12:32 PM   #1
protpibe
protpibe's Avatar
Small subwoofer in rear side panel?
Has anyone attempted to put a small subwoofer behind one of the rear side panels next to the rear seats? I've seen pictures of the panels off and it looks like there's a lot of space back there.
Old 06-14-2014, 11:57 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
not yet.. my 2001 eclipse also suffered from the same condition, and in all the years that car existed, no one did it to that one either..
edit-- i take that back.
http://www.ft86club.com/forums/showthread.php?t=66561
Old 06-18-2014, 03:40 AM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Problem is the depth. I had my entire interior apart last year looking at expanding my existing system. Even at 6" the depth of most mid to top tier subs just are (too deep) for those cavities, obviously 8" and up te magnets get (more depth) needed..
As fellow above mentioned you can customize some small enclosures, I seen that thread however it comes down to enough airspace for the enclosure to work within it's optimum range, the back trunk area is so much easier to work with and obtain te room for .50-1.0 cubic feet enclosures..
Thus resort to back corners and run subs/enclosures there. The best balance comes from that distance anyhow so all good.
Old 06-18-2014, 04:24 AM   #4
Fastbrew
Drives: 2014 Pearl White BRZ
I saw this picture on here:
What do you think about mounting subs and amps in a top box for easy disconnect?
I pulled out my OEM sound tube - I was thinking about hooking it back up and feeding it in from the top box through the antenna hole...
ok - it's bed time
Fastbrew is offline   Reply With Quote
Old 06-18-2014, 06:42 AM   #5
AtlasMick
Drives: FR-S 2013 Asphalt
If you place a 3/4" baffle against the metal behind the rear plastic bits you can fit a sub with 6" depth, 6 1/2" if its a 10" sub and you center it a bit lower as the outside sheet metal curves out toward the bottom.
I fit a 12" sub with 5 3/4" mounting depth.
AtlasMick is offline   Reply With Quote
Old 06-18-2014, 10:42 AM   #6
Z86
Drives: 86 GTS Auto in Pegasus White
Pics pls
Z86 is offline   Reply With Quote
Old 06-18-2014, 12:23 PM   #7
AtlasMick
This is my setup. It's got pictures of the subs outside and inside the car. For reference they are Stereo Integrity BM mkIV. On their website you'll find the 5 and 3/4" mounting depth. They fit quite nicely, but minimal cutting is required.
I'm sure that you could fit the JL 13" in there also, but it might be not enough air space. My recommendation if you do this project is to cut out all the metal you can, relocate electronics and grounds, and make a solid box out of fiberglass. I used the marine grade foam and fiberglass combination and it took countless hours to finally make it fully air tight. Very messy and not fun at all. Definitely not for the faint of heart, you must have balls to do this. Or be stupid and stubborn, like me!
Side marker small metal clips blackfireball5 Want-To-Buy Requests 13 01-04-2017 06:46 PM
Dented rear wheel side panel/rocker panel. Autocon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 12-22-2014 11:18 PM
scrapped lower side panel =( brandonblt2 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 11-07-2014 03:31 PM
Painted 86 emblems (side panel) eddieEndo Scion FR-S / Toyota 86 GT86 General Forum 7 09-07-2013 05:39 PM
How to remove small instrument panel? boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 4 03-02-2013 04:07 PM
