Old 09-06-2013, 10:11 PM   #1
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
Painted 86 emblems (side panel)
I keep looking for a step by step on the forum but have had no luck... for those of you that have done this how did you reapply adhesive after removal of emblem? Do i have to buy brand new emblems with adhesive in order to paint them?
eddieEndo is offline   Reply With Quote
Old 09-06-2013, 11:01 PM   #2
humfrz
If you're referring to the "86-pistons" things, and just wish to paint the background, one person on this forum had his sister paint them red, with nail polish, while on the car ...
humfrz
Old 09-06-2013, 11:06 PM   #3
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Just cover around the emblems and paint over after them
Might want to do it in a garage to reduce wind
Young_makaveli is offline   Reply With Quote
Old 09-07-2013, 06:37 AM   #4
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
3M Automotive Attachment Tape.
http://www.autogeek.net/3m-auto-tape.html
I don't think a DIY is really necessary...
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 09-07-2013, 07:05 AM   #5
BANGER
mad tyte jdm y0
BANGER's Avatar
Drives: 2010 Civic FA1
Send a message via AIM to BANGER
^Dunno if you're linking that as just a sample page but you can also easily acquire that at Walmart, automotive section.
There's also the even beefier/stronger exterior mounting tape, which is 1" width, and should be at the hardware section with all the tapes. If not, Home Depot. Same color and everything, but way stickier. Overkill for a garnish though, but just throwing it out there.
http://img.photobucket.com/albums/1003/Saki_AFA/Civic%202010/86sig.jpg
BANGER is offline   Reply With Quote
Old 09-07-2013, 12:39 PM   #6
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
ordered teh tape, thanks a lot guys!! I would just mask it off but I'm an idiot and I'm 99.99999% sure I would get overspray somewhere I didn't want it lol..
Old 09-07-2013, 05:22 PM   #7
BANGER
mad tyte jdm y0
BANGER's Avatar
Clay bar works on spray paint iirc. Knew someone from another forum got her car maliciously vandalized/spray painted and it all came off clean with a clay bar.
Old 09-07-2013, 05:39 PM   #8
kodyo
Drives: Scion FR-S
Painting these is super easy, I painted mine about 9 months ago.
1) Use dental floss and a thin PLASTIC pointed object to remove the emblem (I used a thin piece of plastic from packaging material and cut a point into it). The dental floss should help cut the tape until you hit one of the pegs used to position the emblem on. Then pull back on the emblem a bit with your finger nails and start slicing and poking at the tape with the plastic piece until the emblem pulls off the car.
2) After pulling the emblem off, I didn't have to use any chemicals to remove the remaining adhesive. Simply rubbed at the adhesive with my thumb till it balled up and came off. I used isopropyl alcohol on the front emblem tape when I rebadged that the second time.
3) Use 3M tape on the back of the emblem and a razon blade to trim it down. Keep protective backing on tape till after painting. Apply tape before you paint since you will need to trim with a razor blade.
4) Used Krylon Fusion (satin black I think) to paint the emblem per instructions on can.
So far, the Krylon has held up well everywhere except the front emblem (debris impact prone). It had a few paint chips, so I took it off after about 6 months and redid it with more coats to hopefully prevent chips.
kodyo is offline   Reply With Quote
WTB - Pair of red painted 86 piston emblems bear89103 Exterior Parts (Aero, Lighting, Etc.) 1 08-05-2013 09:55 PM
Plastidip painted side vents CrashArtist Cosmetic Modification (Interior/Exterior/Lighting) 19 07-13-2013 02:09 PM
WTB five axis rear spoiler whiteout and jdm side vent emblems. darnbry Exterior Parts (Aero, Lighting, Etc.) 3 02-05-2013 04:54 PM
