Old 06-07-2014, 12:32 PM   #1
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Rear Top hats: heim vs rubber
Hello all,
I currently have some rear top mounts that locate the damper shaft via rubber sandwiched by washers.
My question to you all is, will going with the heim style make an appreciable difference? I have some decent dampers and I feel like the rubber bushing could be affecting it's ability to dampen properly. The car is a DD but it's primary existence in life is to autox.
So what do you guys think? Worth the hassle and cost?
Thanks!
RiskyTrousers is offline   Reply With Quote
Old 06-07-2014, 02:10 PM   #2
toeout
I try to use rubber bushings where ever possible. Mine is also DD/autocross car. I have MCS shocks with factory rear upper mounts and heim bottom mounts. Later this year they will replace my heim mounts with rubber bushings.
IME the heim mounts only increase noise and wear out quicker, making the car more high maintenance. I've never noticed appreciable increase in "precision", when I drove a car with pillowball mounts. Also speaking of top mounts, they are stiff enough, that they will not deflect before the shock movement.
toeout is offline   Reply With Quote
WTB: rear top hats and nuts (pairs) g88824074 Want-To-Buy Requests 0 04-22-2014 08:15 PM
wtb: stock front and rear top hats FRS-HHH Want-To-Buy Requests 2 04-03-2014 03:36 AM
FS: Robispec Aluminum Rear Top Hats (SOLD!) jprice130 Brakes, Suspension, Chassis 1 02-20-2014 12:23 AM
Does anyone have the rubber plugs on the struts from rear suspension to avoid water ? dssence Scion FR-S / Toyota 86 GT86 General Forum 0 02-04-2014 03:31 PM
WTB: OEM Rear top hat w/ rubber isolator mit_peid Want-To-Buy Requests 0 06-04-2013 01:36 AM
