Drives: Scion FR-S 10 Series
DD & HPDE Pads
We know that the OEM fluid & pads are not up for the occasional track use.
I installed StopTech P/N 309.11240 (rear) & StopTech 309.11240 (front) Amazon has them for $55 per axle. With a Motil 600 ($18 for 500ml) flush and these pads the brakes stayed true for all 4 of the 30 minute sessions. The OEM pads melt at 700 degrees these have almost double that at 1360 degrees. The fluid is also approximately twice the boiling point. They also do a great job on the street, quiet and reduced stopping distances. I am satisfied with them FWIW Below is their bullet points.. Real $$ savers if only 1/2 dozen or so track days a year Perfect for spirited street and light track use, scorched pad surface delivers a positive bite even when pads are cold High-temperature compound ensures consistent performance and even pad wear Rotor-friendly low-dust formulation makes for cleaner wheels, factory-style shims virtually eliminate pad-vibration noise Perfect factory fit, thanks to precision-cut backing plates |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 05:17 PM |
| Brake Pads and Fluid For DD/AutoX/Track Days/HPDE | ToyoburuBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-23-2016 03:59 PM |
| HPDE / Brake Pads | milhouse | Tracking / Autocross / HPDE / Drifting | 7 | 03-13-2014 01:15 PM |
| HPDE Brake Pads & fluid | Gopherboy6956 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 04-25-2013 10:18 AM |
| HPDE with BMW CCA | Texas BRZ | Southwest | 0 | 09-14-2012 11:46 AM |
