Old 06-06-2014, 08:59 PM   #1
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Moto East Crawford Power Blocks Testing & Dyno!
We recently had a batch of folks come through on the dyno, and it just so happened that we had a car on race gas with a near identical setup to one we just tuned on e85. Only difference? Cat in the exhaust, and power blocks. E85 and 100 octane + will both hit peak torque with no knock.
The cat explains a couple HP at the top end, but the the power blocks and dyno really tell the story here. One is a P&L header (catted), the other is a p&l copy (we won't mention who). But for our purposes they are exactly the same.
Both cars spent several hours on the dyno last year, so for this reason you see the "humps" due to the hyper optimized VE. The more time we spend on the dyno the "rougher" the plot looks with more humps, simply because we can search through all the nooks and crannies for any HP to be had in the spots where VE is just really high. This is normal for an EL header.
So on with the show....see if you can spot the power blocks plot.
So what you can see here is that the power band is shifted. Our VE humps are shifted as well, and the top end we are fortunately able to recover any HP lost by altering cam phasing and increasing the timing. Verdict? Area under the curve is definitely improved. No doubt you will feel these in the 5500-6500 range bit time.
Xero-Limit is offline
Old 06-06-2014, 09:30 PM   #2
D K
Stig's dark passenger
Are thse YOUR power blocks or Crawford?
D
D K is offline
Old 06-06-2014, 10:17 PM   #3
Xero-Limit
Xero-Limit's Avatar
D
Our power blocks usually involve some bricks and windshields for cars that fail to make power--so no, crawford it is (and fixed )
Old 06-07-2014, 06:50 PM   #4
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
So these ~190 whp numbers were on a dynojet with E85 (or 100 octane)?
Just confirming.
Dynojets are usually pretty consistent, I was thinking ~10-15 more whp...
uspspro is offline
Old 06-07-2014, 06:59 PM   #5
xwd
From Mike's description, the darker plot is E85, the lighter plot is 100.
xwd is offline
Old 06-07-2014, 08:11 PM   #6
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Confusing comparison..I give up reading lol
fooddude is offline
Old 06-07-2014, 09:34 PM   #7
Fred E
Drives: WRB BRZ
Darker plot = E85, Crawford power blocks, catted header.
Lighter plot = Race gas, no Crawford power blocks, catless header.
Fred E is offline
Old 06-07-2014, 10:03 PM   #8
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
I think you got that backward, based on Mike's post...
enjoyminutemaid is offline
Old 06-07-2014, 11:28 PM   #9
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Darker plot has the blocks but which fuel is confusing. I believe Shiv posted recently that he wasn't having much luck pairing the power blocks with E85 which was disappointing since that's what I run at the track and I'd love to get more between 5500 and 6500. That bump in the graph would really help the car pull at corner exit.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline
Old 06-08-2014, 12:03 AM   #10
Fred E
Drives: WRB BRZ
Nope, I'm 100% sure I got it right.
Fred E is offline
Old 06-08-2014, 04:54 AM   #11
Xero-Limit
Xero-Limit's Avatar
Color selection could've been better here! Darker is e85. This is a slightly lower reading Dynojet than normal.
Old 06-08-2014, 09:50 AM   #12
xwd
I don't think Shiv ever actually posted a dyno plot. He said the car made more power between 5-6500RPM like other cars with the BPB but it dropped off quite a bit above 6500 so overall the car made less HP.
xwd is offline
Old 06-08-2014, 01:54 PM   #13
Victor Draken
Drives: Toyota Gt86
Are you sure?
The darker One looks like its the One with bpb.
Victor Draken is offline
Old 06-08-2014, 03:06 PM   #14
Fred E
Drives: WRB BRZ
Originally Posted by Victor Draken View Post
Are you sure?
Yes, the one with the Crawford power blocks is the one on E85, which is the darker plot.
Fred E is offline
91 sucks, crawford, mototuned, power blocks
Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers) nelsmar Engine, Exhaust, Transmission 295 08-25-2018 03:19 PM
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Moto-East is back up for service/fabrication/dyno! Xero-Limit NY / NJ / CT / PA 12 11-20-2014 09:17 AM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Moto-East E85 Testing Xero-Limit Engine, Exhaust, Transmission 11 07-23-2013 03:55 PM
