| DIY (Do-It-Yourself) Guides For all DIYs. |
DIY-Scratch & Dent
Note to all you professional paint and body guys I know there is probably some easier/better way. I took this on due to the $48hr labor and 100% mark up on supplies.
Riding to work one morning and a muffler clamp flew from under the car in front of me, skiddered across the concrete and flew up. The clamp mangled my right front fender. Body shop quotes $460-$602 to repair. I decided to tackle it myself. ![]() 1. Sand, Fill, Prime the three nasty dents and scratches. I used 240 grit to get the scratches. Used self etching primer on the one due to it being to the metal. Used glazing putty to fill the voids. ![]() 2. Shot the entire area with filler/primer combo. Sanded with 400 then wet sanded with 1000. ![]() 3. Shot three coats of base coat. I used touch up direct matched to the car. I tried scratch wizards and it didn't match. Wasn't even close. Yes this was shot with a rattle can. ![]() 4. Removed the vent garnish and used a gray scotchbrite pad to scuff the entire fender. I know you can blend clear but you can't with rattle cans and it's easier this way. I did use the crease at the bottom as a stop point. ![]() 5. Important part. I used SprayMax 2k rattle can clearcoat. Don't use the cheap stuff. The clear is $28 a can but it's two part epoxy clear and will go on better and stand up better. ![]() 6. Wet sanded with 1200, then 1500, then 3k to remove the orange peel and got it as smooth as I could. Match was perfect and red is supposed to be difficult to blend. Maybe I got lucky. ![]() 7. Used Meguires ultimate compound and hexlogic orange pad with DA polisher to take out the sand marks. Then polished with Mequires ultimate polish and hexlogic green pad to polish. Could a body shop do it better. Absolutely. Could I have done better. Sure. I learned a lot in the process and saved a lot of money doing it myself. Total cost $125 with paint, clear, primer, sandpaper, and chemicals. |
Looks good. Someday, I'll grow some balls and tackle paint myself.
Drives: 2014 BRZ SWP LTD
We prob need better daylight after pics to prove "perfect" match.
Drives: 2016 STI DGM
Daylight or not, I applaud your massive balls. Well done sir!
Subaru STI :![]() |
Drives: Scion FR-S
well done! I definitely wouldn't have the guts to do this stuff, but props to you .
Addicted
Drives: 2013 Asphalt FR-S 6MT
will sanding remove dents?
Drives: Toyota GT86
Great job!
Thanks
no you need to fill them or pop them out. sand the dent so the filler bonds better
Drives: 2013 FR-S whiteout
dude....nice work.
| Dent :( Will paintless dent removal be able to get this out? | Greg_Di | CANADA | 22 | 08-31-2013 11:22 PM |
| I got a slight scratch dent... | SPEEDGOD | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 02-26-2013 11:37 AM |
| dent / scratch repair | encity5 | NY / NJ / CT / PA | 1 | 12-12-2012 09:09 PM |
| Scratch/Dent Bespoke Unit $340 Shipped | Hanakuso | Audio/Visual, Electronics, Infotainment, NAV | 1 | 11-05-2012 05:20 PM |
| Scratch + dent on rear quarter panel - fix or no? | rawbz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 10 | 08-26-2012 11:50 AM |
