Old 06-04-2014, 12:27 AM   #1
D K
Stig's dark passenger
Question on passenger's window
I'm having the following dilemma:
Pass side window won't work from the driver's side control.
It will work from the passenger's side control and the window button is flashing.
Also, when you open the pass door, the window goes down the normal 5mm, but when you close it, it doesn't go back up like it's supposed to.
Have any of you guys seen this?
D K is offline   Reply With Quote
Old 06-04-2014, 12:45 AM   #2
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I'm on my phone so I can't look up the process for you but to reset is something like hold down the window button for 10 seconds with the door closed?
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 06-04-2014, 12:45 PM   #3
willypongtb
P MAI86
Drives: subaru brz limited
It happen to me one when i mess up with the pass door panel so what i did is.
recalibrate window by (on driver side control panel) all window closed and push hold down passenger side window for 10 sec.
i hope that will help
willypongtb is offline   Reply With Quote
Old 06-05-2014, 01:25 AM   #4
D K
Thanks guys!
Unfortunately for me, it didnt work.
Any more ideas, more than welcome.
D
Old 06-05-2014, 09:11 PM   #5
D K
I don't know what happened but now it works.
Old 06-06-2014, 04:28 PM   #6
Chimera
Drives: FRS
if its 'blinking' that means that the window had some issue.
for me to fix it I lower all the way, hold down like 2 sec, raise all the way and hold 2 sec, and its fine after.
I think it wants you to do a full up/down cycle.
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Passenger Window Sailors14FR-S Issues | Warranty | Recalls / TSB 10 05-04-2014 10:28 PM
passenger window reset?? damaster32 Issues | Warranty | Recalls / TSB 3 03-25-2014 12:00 PM
passenger window issue =.= Jeong Issues | Warranty | Recalls / TSB 0 03-13-2013 08:19 PM
Passenger window mystery FRiSson Scion FR-S / Toyota 86 GT86 General Forum 6 09-07-2012 02:30 PM
