Old 06-03-2014, 01:23 AM   #1
D K
Stig's dark passenger
Hesitation right off idle
Looks like the ecu is not seeing the first 5-10% of pedal movement.
Has anyone seen this?
D K is offline   Reply With Quote
Old 06-03-2014, 01:24 AM   #2
Lemar58
Drives: Scion FR-S
You drive a manual or auto?
Lemar58 is offline   Reply With Quote
Old 06-03-2014, 02:39 AM   #3
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
you reset ecu / unplugged battery recently?
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 06-03-2014, 02:59 AM   #4
D K
Yes manual.
Ecutek tune.
Pedal doesnt respond the first 1/8th" or so pedal travel.
Everything else seems normal. Almost like a dead pedal??
This is with bigger injectors and an sc. No other issues or obvious faults. Just the pdal doesnt respond.
D
Old 06-03-2014, 04:23 AM   #5
vynervt
Drives: GT-86
Originally Posted by D K View Post
Yes manual.
Ecutek tune.
D
Is normal every time your reflash the ECU and reset /unplugged the battery. after few cycle of usage it will go back to normal.
vynervt is offline   Reply With Quote
Old 06-03-2014, 04:41 AM   #6
nelsmar
Yes manual.
Ecutek tune.
D
Sounds like your inejctors are not scaled correctly and your tip in fueling is incorrect. I would talk to your tune about it if I were you.
My flickr - Canibeat
Local magazine scout
Idle dip yomny Software Tuning 38 06-14-2016 05:54 PM
AFR @ Idle woode Forced Induction 12 01-19-2014 08:38 PM
Odd idle jbixel Issues | Warranty | Recalls / TSB 2 11-02-2013 08:35 AM
Hesitation/Cutting out in 5th and 6th gear WRBRZ Engine, Exhaust, Transmission 5 08-05-2013 12:21 AM
To those with the auto -any throttle lag or hesitation at low speed? ahausheer Engine, Exhaust, Transmission 22 07-25-2012 05:21 PM
