Old 06-02-2014, 09:46 PM   #1
cooldandani
Drives:
SUB and AMP!!!
hey guys!!! so im a little confused... i got an amp and sub i want to install but idk what to do with the stock amp? do i unplug it or leave it there, let me know what you guys have done to your cars??
cooldandani is offline   Reply With Quote
Old 06-02-2014, 09:48 PM   #2
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Well the stock amp just runs the front speakers.
Is the amp just for the sub or is it 5 channel for the speakers too?
86-tundra is offline   Reply With Quote
Old 06-02-2014, 09:58 PM   #3
cooldandani
Drives:
its a 4 channel amp which i plan to bride to power just the sub.
Old 06-03-2014, 12:11 AM   #4
86-tundra
Troll Hunter
86-tundra's Avatar
Then just leave the stock amp as is
Old 06-03-2014, 12:15 AM   #5
cooldandani
Drives:
Lol OK cool so I will try this tomorrow wish me luck!!!
Sent from my SAMSUNG-SM-T217A using Tapatalk
The Following User Says Thank You to cooldandani For This Useful Post:
86-tundra (06-03-2014)
Old 06-03-2014, 03:29 AM   #6
paulca
Drives: Toyota GT86 Coupe Red (UK)
If you drive the sub straight from a bridged amp you'll trash it or at very least it will sound like shit unless it has a low pass filter built in.
paulca is offline   Reply With Quote
Old 06-09-2014, 02:51 AM   #7
Guzic
Clean as F86ck
Guzic's Avatar
Drives: 2014 Asphalt FR-S
What I did with mine, a 1 channel amp, I bypassed the stock amp wires and fed them to the aftermarket amps line in port. Them from there I passed the + and - from yhe amp to 2 subs. Let mw know if you need more info. I can even do a DIY if enough people are interested.
Guzic is offline   Reply With Quote
Old 06-09-2014, 03:14 AM   #8
suaveflooder
Here is my wiring on my 13 BSpoke. All I did. No other changes to the system. Sounds GREAT!
suaveflooder is offline   Reply With Quote
Old 06-09-2014, 06:41 AM   #9
speedrye
Drives: White
I removed the stock amp and used a 4-channel amp. Two channels power the front 6.5" door speakers while the other two power the rear 6.5" subs. With a little work the baby Alpine MRV-F300 amp fit nicely in the stock location without creating a bulge in the trunk floor.
speedrye is offline   Reply With Quote
Old 06-09-2014, 01:31 PM   #10
cooldandani
Drives:
Hm lots of great ideas guys thanks so much!!! I would be interested in diy if you could please do it @Guzic!!
Sent from my SAMSUNG-SM-G900A using Tapatalk
Old 06-09-2014, 04:48 PM   #11
Guzic
Clean as F86ck
Guzic's Avatar
I will try to write one up tonight. Unfortunately I do not have in process pics but I will try to show what cables are needed to be bypassed
Old 06-09-2014, 05:28 PM   #12
gramicci101
Off Topic
Driving a sub from any amp without a low pass filter will sound like shit and potentially damage the speaker. Bridged or not doesn't matter. As far as bridging goes, as long as the amp can support it and you match the impedance of the signal with the resistance of the speaker, it's not a big deal. It might raise the THD a little, but at 30 Hz that's not really a problem.
Old 06-09-2014, 07:18 PM   #13
Guzic
Clean as F86ck
Guzic's Avatar
Yes a low pass filter is what will make a difference. A capacitor will also keep the voltage steady for the amp.
