Old 05-31-2014, 09:30 PM   #1
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
Reverse lights always on with new LED bar
I just installed this baby and I just can't figure out why the reverse lights stay on constantly.
I am by no means a pro DIYer so, please, bear with me.
Actually, what's more puzzling to me is why the stock reverse lights DON'T stay on all the time...
Using a volt meter on the stock setup here's what I saw:
  • whether I engage the reverse or not.: ~10 volts at the harness (in the trunk, where it then goes out to the 2 reverse light bulbs)
  • with reverse engaged: ~10 volts at the light socket
  • without reverse engaged: nothing at the light socket
Unless I'm missing something, I don't see any kind of device between the harness and the bulbs that could possibly figure out that the reverse gear is engaged or not...
Now, after installing the new light bar, I'm seeing the following symptoms:
  • reverse lights always on
  • my gear indicator (I have 6MT) shows "R" steady
Any insight appreciated.
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 06-01-2014, 10:56 AM   #2
Enders FRS
Drives: FRS MT SE 10 edition
Ground based relay?
Enders FRS is offline   Reply With Quote
Old 06-02-2014, 09:17 PM   #3
tbertran
tbertran's Avatar
So maybe my car is worse than others when it comes to using LEDs and the fact that low current is sometimes enough to light them up (I also have a hyper blinking issue with some Spyder 2 tail lights).
Is there a "cure all" solution to this problem or should I sprinkle resistors all over the damn grid?
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 07:42 PM
Reverse Lights sixthree Cosmetic Modification (Interior/Exterior/Lighting) 17 04-30-2014 12:14 AM
HID Reverse Lights mezdup Cosmetic Modification (Interior/Exterior/Lighting) 10 06-19-2013 04:47 PM
reverse lights xdbuix Cosmetic Modification (Interior/Exterior/Lighting) 8 06-11-2013 10:00 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
