Old 05-30-2014, 09:05 AM   #1
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
[Question] DRL Bulbs and HID Alternatives
Hi guys, I have a few questions related to replacing bulbs:
DRL
I had a bad experience with some DRL LEDs that I bought from a vendor here, so I'm thinking of going another route. Specifically, I'm thinking of getting Nokya Arctic White bulbs. They have a list of Stage 1 bulbs here: http://mtqinc.com/nokyausa/headlights/aw1/aw1.php. And a list of Stage 2 bulbs here: http://mtqinc.com/nokyausa/headlights/aw2/aw2.php. Now this may sound like an extremely noob question, but which bulbs am I supposed to get? I'm not very technical so I don't know about wattage or anything. Which ones from the list are suitable for our cars?
HIDs
When I first got my car, I just bought some HID bulbs and put them in the stock projectors. I didn't know about retrofitting, and I didn't know this would cause a problem for other drivers. But now that I do know, I want to fix this problem. I don't want to retrofit, so are there other bulb alternatives? I want something brighter and whiter than the stock lights, but HIDs are a no go if I don't plan on retrofitting. Any recommendations on alternative bulbs I can use?
Thanks guys!
i_4got is offline   Reply With Quote
Old 05-31-2014, 12:39 AM   #2
ayephoe
ayephoe's Avatar
Drives: 2014 Scion FRS
HID's are the way to go! Love them! It is nothing big at all to retrofitting. Hook up stock connector to ballast and ballast to bulbs! Simple and clean.
http://www.o-nex.com/h11.html
ayephoe is offline   Reply With Quote
Old 05-31-2014, 01:42 AM   #3
Poodles
Drives: 2015 Series.Blue
DRL
HIDs
Thanks guys!
Modified H9 bulb will fit in the spot of an H11 and still keep the alignment. It's quite a bit brighter.
For the high beam, you could use a modified 9011 HIR bulb (these are not HID, it's a special coating on the inside of the bulb that makes the filaments burn brighter).
Yeah, no...
Old 05-31-2014, 01:49 AM   #4
ayephoe
ayephoe's Avatar
Do you get the same color as hid's with that?
Old 05-31-2014, 10:16 AM   #5
i_4got
i_4got's Avatar
Thanks for the info! But can you explain what you mean by a "modified" bulb?
Let's say I buy the H9 100w bulb on this page: http://mtqinc.com/nokyausa/headlights/aw2/aw2.php. What do I have to do to it to make sure it fits my FRS?
Old 05-31-2014, 10:35 AM   #6
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I have modified H9 arctic white Nokyas in my low beams and they're really not that great. Go with HIDs. Ill probably go back to that eventually. I don't drive enough at night to really care either way though.
Old 05-31-2014, 02:19 PM   #7
Poodles
Color has little to do with performance. But, no, you're not going to get the same look. Headlights are about function first, looks last.
You have to trim the locking nubs, it's not hard. I wouldn't use blue filter bulbs at all. Halogen cycle puts out very little blue, so they have to run the bulbs even harder to get the light out of them. Not to mention that our eyes don't like blue light very much and it makes it harder to see...
See above. Use a good normal H9 bulb, not a coated one.
H11: 1700 lumens
H9: 2100 lumens
9005: 1700 lumens
9011: 2300 lumens
HID's glare in halogen designed headlights because of their differing design goals, alignment, and the standards they have to meet.
race gas and alternatives autobrz Engine, Exhaust, Transmission 3 11-22-2013 08:21 AM
86 Alternatives ??? H8R GTS AUSTRALIA 33 09-05-2012 12:59 AM
Opti-guard alternatives Z86 AUSTRALIA 9 07-12-2012 09:17 PM
Alternatives to BRZ, sub $30k zygrene Other Vehicles & General Automotive Discussions 123 05-08-2012 12:23 AM
Nav alternatives? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 33 04-13-2012 04:27 PM
