Old 05-29-2014, 09:02 PM   #1
Fear
Drives: Ft86
FI tuning question
Can the tune cause rod failure?
Fear is offline   Reply With Quote
Old 05-29-2014, 09:40 PM   #2
sw20kosh
Drives: 2013 Black FR-S
I don't even...
Old 05-29-2014, 10:17 PM   #3
Knock from a bad tune can cause a rod to bend, yes.
Old 05-29-2014, 10:35 PM   #4
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 05-29-2014, 11:19 PM   #5
sw20kosh
Originally Posted by evo4g63 View Post
I feel like something big is about to happen.
Old 05-29-2014, 11:20 PM   #6
Fear
Drives: Ft86
I know little to nothing about tuning so this is my attempt to becoming better informed...
I'm not mentioning any names but this is what I have been informed (summarizing);
Since our cars were not made for boost they can not handle the extra power. I was advised against pushing E85 tune above 400WHP and my Gas beyond 270 because the rods will fail.
After seeing dyno graphs again and again in the contrary to this i'm in search of more information.
thoughts?
Old 05-29-2014, 11:28 PM   #7
sw20kosh
thoughts?
It all depends on the tune. If you have a rock solid tune where you are within the limits of your fuel/knock and you are not pushing it beyond those limits, then your engine should not fail unexpectedly. It will incur more wear and tear as expected.
270 - 280 is about what I can achieve safely on CA 91 octane with a GT3076 where I am within the limits of my fuel.
E85 is another story. Obviously the more torque the motor is making... the more wear and tear and the more prone it will be that something not engineered for 300 - 350 wtq will break.
Old 05-29-2014, 11:40 PM   #8
Fear
Drives: Ft86
I understand that, but two motors have failed within 1 month of the tune. Shop says it the rods and not the tune. I'm just trying to get educated, not point fingers
Old 05-29-2014, 11:45 PM   #9
evo4g63
evo4g63's Avatar
You had two engines fail? I would say very much so that your issue is with tuning of this indeed occur. Do you have any of the logs?
-2016 Subaru WRX
Old 05-29-2014, 11:46 PM   #10
s2d4
s2d4's Avatar
Which shop?
Old 05-29-2014, 11:47 PM   #11
Fear
Drives: Ft86
Not my motors, and i'm not naming names. Sorry guys. Just trying to educate myself on the issue... Rods, power and tunes
Old 05-29-2014, 11:49 PM   #12
doberman8u
Drives: 2013 FR-S, 2004 Z06
+1 while those that can best provide valuable feedback must also approach with a solid cover your a** underlying theme throughout the delivery.
Should be fun
doberman8u is offline   Reply With Quote
Old 05-29-2014, 11:54 PM   #13
s2d4
s2d4's Avatar
Awesome context bro, no logs, no tuners to drive conclusions from is kind of hard to pin point issues.
It is almost like trying to find the gene that makes two kids fall down a hole, without knowing where, size, ample warning or was the kids retarded or their parents taught them jump in every single hole they see.
Old 05-30-2014, 12:03 AM   #14
Fear
Drives: Ft86
Its not an "issue" thread... Its a "can the tune bend rods"
I was told by the tunner they pull timing to cut power to prevent rods from bending...
Ecutek new tuning question beforprez Software Tuning 4 05-09-2014 10:29 PM
Noob question about tuning CamryDS Engine, Exhaust, Transmission 8 06-27-2013 12:29 PM
ECU Tuning Question Ahernandez0909 Engine, Exhaust, Transmission 15 03-24-2013 02:03 AM
Question about tuning and pedal play.. chadstyle BRZ First-Gen (2012+) — General Topics 3 01-20-2013 12:36 PM
DDM Tuning Lighting Question! SMOKETREES Cosmetic Modification (Interior/Exterior/Lighting) 0 09-27-2012 05:55 PM
