Drives: 2013 Argento 6mt
Anybody else have noises after lowering?
Anybody else getting popping noises on uneven surfaces after being lowered? My car just recently starting doing this and I'm not sure where the problem lies. It's not the struts or control arms. It's definitely not ball joints or bushings. At this point I'm thinking its either the sway bar end links or the chassis itself flexing and popping. I'm lowered on h&r super sports with koni struts; also have whiteline lower control arms, and whiteline roll center/bump steer correction.
Undisputed El Presidente
Drives: Zenki 37J ZN6
Yes. Its gonna make more noise after lowering. I would guess sway bar is binding as a lot of the noises go away with adjustable links it seems.
Drives: 2013 FR-S, 2012 MCS
I have a rolling/sliding type noise like something is loose in the rear (it might be the seats actually) when I take a bumpy turn, such as a driveway. But that's it for me. RSR Superdowns and nothing else.
I had a weird popping noise after lowering my car on RCE yellow springs. Then I found out I didn't tighten down the front sway bar end link nut to the strut.
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
did you use an impact gun to undo the center nut? most people who have basically killed their shocks, but these are on the stock ones. if you didn't, maybe the center nut isn't tightened all the way. this happened to me when I tightened the nut before lowering the car and loading the wheels. i'm on H&R super sports also.
SC10N FR-S #435 of 2500
PROUD OF BOXER
Drives: Raven FR-S
call me crazy, but i think i have the same situation with my rsr's installed as well
#7 | |
Just a dude
Drives: Scion FR-S 2013
If everything's been tightened properly and installed correctly nothing should make noise. Unless you're past -1.5" from stock nothing should come in contact to any of the components clearance wise.
#10 | |
PROUD OF BOXER
Drives: Raven FR-S
My initial guys was that I preloaded the trailing arms and it might be contributing to it. My plan of action is to re torque everything back there
#11 |
#12 | |
Drives:
Happened to me before too. The nut came off and the front sway bar just kept clanking around. Drove me nuts trying to figure out where the clanking was coming from. |
#13 |
Drives: 2013 Scion FR-S 10 Series #1864
im on RSR Superdowns and have not experienced any issues or noises...
| Transmission Grinding and fuel pump noises | FRSChris13 | Issues | Warranty | Recalls / TSB | 14 | 09-15-2014 05:23 PM |
| Pebbles and road debris noises | FatFree | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 12-18-2013 10:10 PM |
| various noises | abutterman | Issues | Warranty | Recalls / TSB | 0 | 10-23-2013 12:26 AM |
| strange coilover install noises/ tried everything | NemeGuero | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 02-26-2013 11:02 PM |
