Old 05-26-2014, 08:32 PM   #1
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
3 Wheels is better than... ?
Can someone please explain! I always felt it, but now I recorded it:
[ame]http://youtu.be/ywJM6eg4Wyw[/ame]
Also, at work, with a steeper (but clearable) incline, it gets MUCH higher, according to co-workers.
What's going on?! I have Eibach Pro-Kit Springs and 25mm FR / 19mm RR sways.
hamzam is offline   Reply With Quote
Old 05-26-2014, 08:34 PM   #2
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
thats what swaybars do by definition. is this a real question?
Old 05-26-2014, 08:37 PM   #3
hamzam
hamzam's Avatar
My first car I did sway bars on. But I had no idea it would make things that stiff just going up a driveway. But I understand now, thanks.
Old 05-26-2014, 08:38 PM   #4
Reaper
Reaper's Avatar
Drives: violent
yup.
Old 05-26-2014, 08:39 PM   #5
hamzam
hamzam's Avatar
What does the weight of a sway bar effect?
Old 05-26-2014, 08:42 PM   #6
Reaper
Reaper's Avatar
Drives: violent
i edited my response. i read it as "my first car, I did sway bars on" like you were saying you did it on a car before this one.
Old 05-26-2014, 09:16 PM   #7
speedrye
Drives: White
The stiffer/thicker the sway bar, the less movement you'll have. That means less movement in corners, but also on entering a driveway. In your case, a thicker sway bar would mean that your inner tire would be higher off the ground than a car with a stock sway bar or no sway bar at all.
speedrye is offline   Reply With Quote
Old 05-26-2014, 09:19 PM   #8
gramicci101
Off Topic
It's not the weight, it's the increased lateral stability upgraded swaybars impart. The swaybar's job is to minimize independent suspension movement between the two sides, which keeps the car from having too much body roll in corners. The wheels can move up and down together, as if you were going over a speedbump, but it's a lot more difficult for one to go up while the other goes down, as they would going around a corner. In this instance, where the suspension would flex independently to go up the curb, since the wheels are tied together you lift a wheel.
Old 05-26-2014, 10:11 PM   #9
hamzam
hamzam's Avatar
That breaks it down great, much appreciated!
Old 05-26-2014, 10:36 PM   #10
fatoni
why are we all talking about sways? 3 points must always be on the same plane but 4 dont have to. the angle you drive out of the driveway yields a situation where the 4th point is further away from the plane than you have available droop travel. i dont think a swaybar is going to limit droop travel like that.
Old 05-26-2014, 10:56 PM   #11
gramicci101
Off Topic
It will when one corner is being compressed and the swaybar is strong enough to lift the opposite corner.
Old 05-27-2014, 12:15 AM   #12
Poodles
Drives: 2015 Series.Blue
Given that he backed out just fine and it didn't do it, I'm more inclined to believe it's the speed involved and the dampers not dropping fast enough to keep the tire on the ground (plus maybe weight transfer, etc)
Old 05-27-2014, 12:41 AM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Look at the angles. Backing out was straight more or less, not at all on entry. Sway bars will cause the wheels to lose independence (which matter less on a more straight on entry/departure), droop travel (lack thereof) also causes this.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-27-2014, 04:58 AM   #14
Poodles
Yeah, it's hard to tell, but it definitely looks faster when he lifts the tire.
Should just be glad the twins have such a stiff chassis
Forgestar F14 wheels and Enkei wheels: <<RPF1 18x9.5/NT03+M 18x9.5 In Stock>> b2autodesigns Wheels and Tires 850 09-10-2017 08:29 AM
Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! Evasive Motorsports Wheels and Tires 4 07-29-2013 08:46 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
