Old 05-25-2014, 10:13 PM   #1
KevinTJH
Drives: Toyota GT86 RED
Would these 18inch wheels fit?
I apologise if a thread like this has been started before. I don't know jackshit about wheels so I desperately need some good advice here.
I've got the base GT model with stock 16" wheels at the moment. I'm thinking of moving up to 18" with these:
http://www.ozzytyres.com.au/store/wh...e-package.html
and choosing Lexani LX9 tyres to go with that package (thoughts?).
Would these new wheels be a simple swap or would it be more complicated than that?
Also, seeing as the new bigger wheels would make the car higher, is it an expensive process to lower the car to where it is at the moment with the stock wheels?
Thanks in advance for your input!
KevinTJH is offline   Reply With Quote
Old 05-25-2014, 10:31 PM   #2
austin_kw
austin_kw's Avatar
Drives: 2013 Scion FR-S Firestorm
Yes, they will fit.
Go for a wider rim!
austin_kw is offline   Reply With Quote
Old 05-25-2014, 10:32 PM   #3
phrosty
18x7.5 is fine unless they've got a wicked high offset. Can't say for certain without knowing that.
The Lexani LX9 will be insanely huge. You want 225/40R18 tires.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 05-26-2014, 02:19 AM   #4
KevinTJH
Originally Posted by austin_kw View Post
Yes, they will fit.
Go for a wider rim!
I would but that particular design doesn't come any bigger than 18".
So Lexani LX7 it is then? I don't know anything about tyres, if you click the link I posted, there will be a selection of tyres to choose from, would any brand within those specs be good?
I've looked through all of them, and I personally like the Lexani LX pattern the most.
What about lowering the car?
Old 05-26-2014, 04:58 AM   #5
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
By wider, he meant wider than 7.5", not a greater diameter than 18".
The tires that came on your car were about 24.7" in diameter; a 40 series tire in a size like the one suggested (225/40-18) will be about 25.1" in diameter. I'll let others weigh in as to whether or not that is too tall to run without rubbing.
dradernh is offline   Reply With Quote
Old 05-26-2014, 10:25 AM   #6
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I run 18x7.5 +48mm with 225/40/18 tires and a one inch drop without any rubbing problems whatsoever. It is a very conservative size as far as aftermarket wheels are concerned (the wheels are tucked in a bit).
mit_peid is offline   Reply With Quote
Old 05-26-2014, 10:30 AM   #7
KevinTJH
So that's pretty much identical to what I'm thinking of getting?
If it's not too much of a hassle, would you mind sharing a photo? It's hard to see from your profile picture.
Did you also lower your car? If not, how much higher is the car in comparison to the stock wheels?
Old 05-26-2014, 10:35 AM   #8
mit_peid
Boosted Noob
mit_peid's Avatar
I'm on vacation right now so not with my car. When I said one inch drop I meant I lowered my car by one inch from stock height. It fits and looks good, but some people will tell you the wheels aren't flush enough. It is still very functional and in reality your tire choice has way more to do with performance than any attempt at getting hella flush.
Old 05-26-2014, 04:54 PM   #9
phrosty
The LX7 will work fine, but a 35% height will provide a less smooth ride than a 40% due to less rubber between road and wheel. For reference, stock tire is 45%.
Old 05-26-2014, 05:55 PM   #10
KevinTJH
Oh I see, now I know what that number means. So that means the LX9 would be 60%? no wonder they were said to be massive tyres!
Alright I'll keep an eye for either a 40% or 45% then.
So I'll just get those rims and lower my by an inch. Shouldn't be a problem right?
FS: SSR MS3 3 piece 18inch wheels!!!! 86design Wheels and Tires 21 07-27-2013 10:40 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
$$FS: 4x 18Inch Blk/Red Drag Rimes+4x Continental Tires "INDIANA"$$ FRS-Jay Wheels and Tires 0 11-01-2012 03:14 AM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
