| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: ‘22 BRZ, ‘18 Crosstrek
Vibration/shake in drive train
3 month old '14 BRZ limited with auto transmission.
When starting out turning either right or left, my BRZ shudders and shakes ever so slightly. The car is in normal drive mode. Have you experienced this situation and/or what do you think could be causing this? |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Its the Torsen diff locking up I bet, my manual '14 Sport Tech does it too, changing the diff fluid did nothing and the dealer thinks its normal.
Drives: 2013 Raven FRS MT
Normal.
Drives: BRZ DGM Limited
mine does the same , especially when turning from a dead stop
Drive From Home
Drives: BRZ STI Performance
That's your Torsen Diff. working dude especially on uneven / bad pavement.
Drives: 2015 Series.Blue
Yep, a bit normal with a torsen (clutch style LSD would be worse). If the torsen in the Miata is anything like this one, it will get better as it ages.
Feel better now...Nothing wrong with my new BRZ!!!! Thanks for your replies!
| **Kleinn For Auto TRAIN AIR HORN #220 & 150PSI SEALED AIR COMPRESSOR +TANK #6275 pkg* | 468Power | Exterior Parts - The Rest | 2 | 07-11-2013 04:42 PM |
| Drive train bushing advice | wootwoot | Engine, Exhaust, Transmission | 6 | 06-03-2013 04:13 AM |
| Harlem Shake | Simpleviet | Northern California | 14 | 02-14-2013 12:23 PM |
| Rev Shake | injuryexpert | Issues | Warranty | Recalls / TSB | 0 | 11-21-2012 09:56 AM |
| Valve Train Adjustments | @Art_Mighty | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 09-24-2012 09:10 PM |
