Old 06-02-2013, 04:49 PM   #1
wootwoot
Drives: FRS
Drive train bushing advice
I have a set of sti motor mounts on order. I figured I might as well do them while I am changing out my header. Sti recommends that you change the transmission mount with the motor mounts. This makes sense as stiffer motor mounts and a soft tranny mount could cause some stress in various parts of the car. I already have a whiteline trans insert, subframe inserts, and diff inserts. My question is as follows: do you think my drivetrain is stiff enough as is to run the new motor mounts with no ill effect? Or is it worth the cash to buy the sti trans mount as well?
wootwoot is offline   Reply With Quote
Old 06-02-2013, 05:14 PM   #2
OrbitalEllipses
Drives: Attitude
The STI trans mount would invariably be better than the stock mount, but you've already got a stiff piece of urethane jammed into the void of the stock mount. I wouldn't bother getting the STI mount unless you wanted every last bit of stiffness (and perhaps didn't want poly).
Save the $200 or however much it costs.
Old 06-02-2013, 05:20 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
agreed
Old 06-02-2013, 07:39 PM   #4
wootwoot
Drives: FRS
The sti mount would be nice because it would require no maintenance. But I think the whitleine material is fairly low maintence/low noise anyway. More then anything I just want to make sure the mounts and the bushing play nice together.
Old 06-02-2013, 07:50 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You have no idea (or maybe you did read my thread on motor mounts change), but this is an AWESOME decision. It will save you so much grief doing both at the same time.
Also, you will be fine with the Whiteline tranny mount insert. Don't sweat it.
Old 06-02-2013, 08:08 PM   #6
wootwoot
Drives: FRS
Ya... I actually got the idea by reading that thread.
Old 06-03-2013, 04:13 AM   #7
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
Yeah, so it looks like I'm going to be doing motor mounts as soon as I change headers. (Not tracking, but going FI eventually.)
Thanks for going through the trouble for us @Sportsguy83!
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Bushing install help wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-01-2013 01:18 AM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
Valve Train Adjustments @Art_Mighty Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-24-2012 09:10 PM
Does the STI Rear Shifter Bushing fit the BRZ/FRS? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-27-2012 03:48 PM
Car Advice Toyota 86 review prototype drive Mess11 Scion FR-S / Toyota 86 GT86 General Forum 12 12-05-2011 01:10 AM
