Old 05-22-2014, 10:59 AM   #1
liajet24
Drives: Argento FRS
Headers without a tune?
I purchased the Borla UELs but I don't want to get a tune and void my warranty. Ft86speedfactory said it shouldn't be an issue, but I am a little worried that the engine might start running lean. Can I still run them for the next two years until my warranty runs out before getting a tune?
liajet24 is offline   Reply With Quote
Old 05-22-2014, 11:07 AM   #2
toyotaAlex
toyotaAlex's Avatar
Drives: 2013 Scion FR-S Auto- OFT Stage 2EL
Buy the openflash tablet. Flash to the stage 2 Uel tune. If you need to go to the dealer for warranty use the oft to flash back to stock map. Takes 10mins to flash.
2013 Scion FR-S Auto, OFT Stage 2 Equal length 94oct, Hollowed out Factory Manifold, Stock Overpipe, Hollowed Front Pipe, Stock Midpipe with Resonator Removed, Custom Axleback with Single Exit and a Flowmaster 50series Muffler. Stock Airbox with all resonators removed, Snorkel shortened, TRD Panel Filter.
toyotaAlex is offline   Reply With Quote
Old 05-22-2014, 11:17 AM   #3
liajet24
Drives: Argento FRS
There is no flash counter? and is there a tune for my Borla UEL, Nameless DP/OP and TRD Ctback?
Old 05-22-2014, 11:19 AM   #4
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
Also curious about the flash counter, I know GM and Ford have been doing it for a few years now.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 05-22-2014, 11:23 AM   #5
2pt5RS
Berz
It's an n/a car...you don't *need* a tune for performance parts. It will run just fine.
2pt5RS is offline   Reply With Quote
Old 05-22-2014, 11:34 AM   #6
Malt
Drives: 2015 WRX
I've heard about this mythical flash counter and I have yet to see any evidence for it. OP: minus a header, you don't need a specific tune for those as they don't do anything except add volume to your exhaust. The Stage 2 UEL tune from shiv will work fine for what you have.
While you may not "need" a tune, depending on what you mod you may end up with worse performance, worse mileage, or a poorly running engine without tuning for the mods. Anyone suggesting running a catless header without tuning for it obviously does not know what they are talking about.
Malt is offline   Reply With Quote
Old 05-22-2014, 11:41 AM   #7
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
you dont want to void your warranty with tuning but you bought headers that removes emission equipment?
Digitalanalog is offline   Reply With Quote
Old 05-22-2014, 11:43 AM   #8
iAgui
iAgui's Avatar
Drives: 2014 SWP Subaru BRZ
I agree with Malt. Even if the mythical flash counter does exist, it's not something the dealer can just check on a whim. From what I understand, they have to send off your ECU to be inspected.
And at that point, something CATASTROPHIC must have happened, since the dealer is willing to go to such lengths in order to deny you warranty work.
I say buy an OpenFlashTablet, flash shiv's Stage 2 UEL Tune, and enjoy your ~25 more horses.
If needed, flash back to stock and remove your headers before having warranty work done.
iAgui is offline   Reply With Quote
Old 05-22-2014, 11:44 AM   #9
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
6000 miles, 3 track days, and a bunch of autocrosses with JDL UEL catless headers, over pipe, catted front pipe, Invidia catback, and an O2 spacer for second sensor (with the occasional CEL but very rare) on stock ROM.
There was an improvement in power over stock, as much as with a tune? Surely not.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 05-22-2014, 11:49 AM   #10
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
You already voided your exhaust component warranty by installing Borla UELs....
To avoid any engine issues, you should get a tune for safe operation.
drewbot is offline   Reply With Quote
Old 05-22-2014, 02:14 PM   #11
toyotaAlex
toyotaAlex's Avatar
Use the stage 2 uel tune. ALL TUNES INCLUDED FREE OF CHARGE!!!!!!
Best $500 I have ever spent on my car.
Old 05-22-2014, 02:18 PM   #12
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
You definitely want a tune with a header. It will usually double (sometimes triple) the gains you get from header alone.
Xero-Limit is offline   Reply With Quote
Old 05-22-2014, 02:20 PM   #13
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
Header without the Tune is like Cereal without Milk.... It works, but works better with the other .
Migero86 is offline   Reply With Quote
Old 05-22-2014, 08:14 PM   #14
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
I ran the RevWork UEL for a few months with an O2 spacer and without a tune and still got a CEL. You're already voiding your warranty by replacing the headers.
I highly recommend getting a tune. You can probably get away without a tune, but not for very long. You risk running too lean and possibly blowing something
Jolaessss is offline   Reply With Quote
Got a custom tune on the FRS. What happens if i add aftermarket headers after? AceNiNe Software Tuning 5 03-02-2014 10:50 PM
Result of the dyno tune at PRE with my JDL headers stockysnail Northwest 4 11-15-2013 06:31 PM
Is it a bad idea to run headers without a tune?? Mike86 Engine, Exhaust, Transmission 48 09-06-2013 03:31 PM
MPG w. Headers and Tune Cjymiller Engine, Exhaust, Transmission 5 05-17-2013 06:47 PM
Tune now or wait for headers lbroskee Engine, Exhaust, Transmission 7 05-01-2013 05:36 PM
