Drives: Argento FRS
Headers without a tune?
I purchased the Borla UELs but I don't want to get a tune and void my warranty. Ft86speedfactory said it shouldn't be an issue, but I am a little worried that the engine might start running lean. Can I still run them for the next two years until my warranty runs out before getting a tune?
#2 |
Drives: 2013 Scion FR-S Auto- OFT Stage 2EL
Buy the openflash tablet. Flash to the stage 2 Uel tune. If you need to go to the dealer for warranty use the oft to flash back to stock map. Takes 10mins to flash.
2013 Scion FR-S Auto, OFT Stage 2 Equal length 94oct, Hollowed out Factory Manifold, Stock Overpipe, Hollowed Front Pipe, Stock Midpipe with Resonator Removed, Custom Axleback with Single Exit and a Flowmaster 50series Muffler. Stock Airbox with all resonators removed, Snorkel shortened, TRD Panel Filter.
#3 |
Drives: Argento FRS
#4 |
head of infinite swagger
Drives: 2013 FR-S 6MT
Also curious about the flash counter, I know GM and Ford have been doing it for a few years now.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
#5 |
Berz
It's an n/a car...you don't *need* a tune for performance parts. It will run just fine.
#6 | ||
Drives: 2015 WRX
While you may not "need" a tune, depending on what you mod you may end up with worse performance, worse mileage, or a poorly running engine without tuning for the mods. Anyone suggesting running a catless header without tuning for it obviously does not know what they are talking about. |
| The Following User Says Thank You to Malt For This Useful Post: | iAgui (05-22-2014) |
#7 | |
Drives: '13 BRZ Limited, '95 BMW M3
| The Following 8 Users Say Thank You to Digitalanalog For This Useful Post: | Annahra (05-22-2014), drewbot (05-22-2014), horrorbiz (05-24-2014), Mad1723 (05-23-2014), MagicBobert (05-23-2014), Malt (05-22-2014), nikitopo (05-28-2017), youcantseeme24 (05-22-2014) |
#8 |
Drives: 2014 SWP Subaru BRZ
I agree with Malt. Even if the mythical flash counter does exist, it's not something the dealer can just check on a whim. From what I understand, they have to send off your ECU to be inspected.
And at that point, something CATASTROPHIC must have happened, since the dealer is willing to go to such lengths in order to deny you warranty work. I say buy an OpenFlashTablet, flash shiv's Stage 2 UEL Tune, and enjoy your ~25 more horses. If needed, flash back to stock and remove your headers before having warranty work done. |
| The Following User Says Thank You to iAgui For This Useful Post: | zdr93523 (05-23-2014) |
#9 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
6000 miles, 3 track days, and a bunch of autocrosses with JDL UEL catless headers, over pipe, catted front pipe, Invidia catback, and an O2 spacer for second sensor (with the occasional CEL but very rare) on stock ROM.
There was an improvement in power over stock, as much as with a tune? Surely not.
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
| The Following User Says Thank You to SubiePig For This Useful Post: | husker741 (05-22-2014) |
#10 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
You already voided your exhaust component warranty by installing Borla UELs....
To avoid any engine issues, you should get a tune for safe operation. |
#11 | |
Use the stage 2 uel tune. ALL TUNES INCLUDED FREE OF CHARGE!!!!!! Best $500 I have ever spent on my car.
#12 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
You definitely want a tune with a header. It will usually double (sometimes triple) the gains you get from header alone.
| The Following User Says Thank You to Xero-Limit For This Useful Post: | Migero86 (05-22-2014) |
#13 |
Drives: 2015 Trailhawk
Header without the Tune is like Cereal without Milk.... It works, but works better with the other
#14 |
Drives: SWP FR-S
I ran the RevWork UEL for a few months with an O2 spacer and without a tune and still got a CEL. You're already voiding your warranty by replacing the headers.
I highly recommend getting a tune. You can probably get away without a tune, but not for very long. You risk running too lean and possibly blowing something
| Got a custom tune on the FRS. What happens if i add aftermarket headers after? | AceNiNe | Software Tuning | 5 | 03-02-2014 10:50 PM |
| Result of the dyno tune at PRE with my JDL headers | stockysnail | Northwest | 4 | 11-15-2013 06:31 PM |
| Is it a bad idea to run headers without a tune?? | Mike86 | Engine, Exhaust, Transmission | 48 | 09-06-2013 03:31 PM |
| MPG w. Headers and Tune | Cjymiller | Engine, Exhaust, Transmission | 5 | 05-17-2013 06:47 PM |
| Tune now or wait for headers | lbroskee | Engine, Exhaust, Transmission | 7 | 05-01-2013 05:36 PM |
