It's the Mad Cow
What possible Leaks have you found/fixed under the Intake Manifold?
Seem's while having a ton of fun on the way home I found yet another hose that can blow off under boost.... why are there things under the IM that I can't see dammit.
The first one was the Fuel Tank Vapor Line that has no clamps on it. Tonight I checked that it is still on. I cannot find any leaks from looking or trying to feel while hot so I am looking for some help in narrowing down all the possibles so I can hopefully pull the Intake Manifold if I have to and prevent all of this from happening again. Thanks
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
There are 3 under the intake manifold. 1) Under the throttle body that leads to 2) Vacuum side of the evap solenoid, and 3) Inlet side of the evap solenoid
Taken from the thread started by SBD
![]() Edit: If you remove the A/C compressor and throttle body, all 3 points are easily accessible. There are also 2 vacuum lines that lead to the top of the intake manifold (under the D4S cover). If you still have a vacuum leak, fire up a cigar and blow into a vacuum hose
It's the Mad Cow
Thank you I think I know which one it is now... Now to find a way to get at least a zip tie on them.
#5 | |
It's the Mad Cow
Either way thank you very much for the picture that is EXACTLY what I needed, I owe you a beer!
It's actually really easy once the compressor and TB are out of the way.
#7 | |
I've read that some late production ones have clamps on the hoses, but I think it's safe to say that most do not. I think the picture is an "after" shot, once the clips were installed
Drives: 2022 BRZ Limited
see my recent post in the KW owners thread
http://www.ft86club.com/forums/showp...postcount=1097 it seems like I forgot the one right behind the throttle body (which is a lot easier to reach compared to other two btw) I will soon put a clamp on that too..
NASA SpecE30 Racer
That pic was taken after the clamps were installed. They happened to use factory style clamps. I used traditional jubilee clip style hose clamps on mine.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| Intake Manifold | Bu-Tang | Engine, Exhaust, Transmission | 29 | 12-06-2014 01:43 PM |
| Oil on/around Intake Manifold | Wepeel | Issues | Warranty | Recalls / TSB | 2 | 05-12-2014 11:40 PM |
| Found the source of a rattle, and fixed it! | BRZnut | Issues | Warranty | Recalls / TSB | 10 | 05-08-2014 10:39 PM |
| Aluminium intake manifold? | Hempo | Engine, Exhaust, Transmission | 18 | 06-27-2013 01:19 PM |
| WTB: intake manifold | carlitosway6891 | Engine, Exhaust, Bolt-Ons | 0 | 06-22-2013 02:24 PM |
