Old 05-20-2014, 03:07 PM   #1
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
Claybarring headlights
Hey guys,
To get rid of grime on headlights, what do you think about using claybars on the outside? Pros, cons? I tried it on my fiance's Mazda 3 headlights (used and old already hehe) and I think it made a bit of a difference.
Thoughts?
Wilso is offline   Reply With Quote
Old 05-20-2014, 03:29 PM   #2
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Can't think of anything bad that can happen, since you are just picking up contaminants off the headlights. As long as you keep folding the claybar after each wipe, should be fine.
Myv is offline   Reply With Quote
The Following User Says Thank You to Myv For This Useful Post:
Wilso (05-22-2014)
Old 05-20-2014, 03:33 PM   #3
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Won't hurt a thing. I classy the windows too.
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
Wilso (05-22-2014)
Old 05-20-2014, 03:43 PM   #4
Namuna
Namuna's Avatar
I clayed my headlights just the other day, before applying vinyl tints.
Far as I'm concerned, the cleaner and more contaminate free the headlights, the better the vinyl tint adhesion. Which results in better longevity and lesser bubbles...For general purpose just keeping them clean though, I personally don't bother going to that level but I agree with the other comments that it doesn't hurt if you want to be that OCD about it.
Namuna is offline   Reply With Quote
The Following User Says Thank You to Namuna For This Useful Post:
Wilso (05-22-2014)
Old 05-22-2014, 01:02 PM   #5
Wilso
Thanks guys! I just want to prevent them from getting to
That really aged and foggy look, trying to be proactive lol
Old 05-22-2014, 04:47 PM   #6
White64Goat
Clay bar will probably not help with preventing hazing, only removing any imbedded dirt.
Old 05-28-2014, 04:36 AM   #7
Tuan
Tuan's Avatar
Drives: Whiteout FRS
Send a message via AIM to Tuan
The headlamp lens are protected by a clear coat paint. Overtime the clear coat will degrade (oxidize) and become hazy due to UV exposure. The best way to prevent this from happening is to regularly wax/seal your headlamps as you would the paint. Using anything abrasive (color sanding/wet sanding) will ultimately reduce the life of the clear coat. A clay bar should be fine, as long as you follow with wax.
When the clear coat fails (maybe 5 years down the line), you can completely sand the yellow oxidized clear coat away and buff the plastic until its clear. However, there's no longer a UV barrier protecting the plastic, and after a few years you'll get degradation WITHIN the plastic itself and on the surface resulting in a slight haze to the lens, no matter how much sanding or buffing you do.
Ultimately, the best way to protect your car is to park your car in a garage away from UV radiation/heat from the sun (not all of us are in a situation to do that) - next is to protect the surface with a sealant/wax with UV protectant properties.
Hope that helps
Tuan is offline   Reply With Quote
The Following User Says Thank You to Tuan For This Useful Post:
Wilso (05-28-2014)
FS:NY Headlights GT86drifter Exterior Parts (Aero, Lighting, Etc.) 0 03-12-2014 01:32 PM
Trade FRS headlights for BRZ headlights? Teknian_Culprate13 Exterior Parts (Aero, Lighting, Etc.) 10 07-14-2013 08:11 PM
WTB: Headlights FR-S/BR-Z official_george Exterior Parts (Aero, Lighting, Etc.) 1 06-03-2013 01:03 AM
Best Headlights?! koyv90 Cosmetic Modification (Interior/Exterior/Lighting) 14 10-23-2012 08:40 PM
