Drives: 2013 BRZ Sport Tech White Pearl
Transmission is damn hot...
I was doing some quite spirited driving yesterday, and kept thinking my heat was on, which I was checking and it was on the coldest setting (without AC). After a while a notuiced the shifter was actually getting pretty warm, and then I put my hand down by the transmission and the floor and everything was QUITE toasty.
I know this car is pretty low to the ground and the transmission is basically sitting beside you, but this is the first time I noticed this. I was driving around town with a lot of 0-60 pulls going on. Has anyone else noticed this? I'd assume it's normal and I just never noticed it. Outside temp was about 18*c. |
Thanks
its normal, wait for summer
Drives: 2013 Scion FR-S 6spd, Whiteout
A quick run down the 102 should cool her off. It's a nice day for a run to Truro anyway.
#4 | |
I've been considering changing my fluid to something a bit more "performance" and recently have really contemplated not driving my car next winter so some Redline or Gear 300 might be in order. I know that won't help with the temps... |
Don't forget that the exhaust runs under there too, so that'll heat up a bunch when you're pushing it harder.
Just a dude
Drives: Scion FR-S 2013
Seeings how FI kits like Ptuning run a turbo literally right beside tranny it has to be no concern really.
in orbe terrum non visi
Drives: violent
The transmission is no where near your hands. Its next to your feet. Remember the outputshaft is near the shifter and the transmission is foreward of that. Underish the radio.The heat was probably your exhaust. Rhd?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#8 | |
It doesn't look like this should be much of a concern! I'd say some of the heat was being generated from the exhaust as well... |
#9 | |
Just a dude
On that note once have car on jackstands again take a boo. If you pop off drive shaft lots of room to work there, you could easily install some thermal barrier if you wanted to, easy to clean that area prior to installation and also would be easy to apply. I plan this next winter on spraying on some MLV Zero noise and thermal barrier in that tunnel area myself.
#10 |
Not sure if changing the transmission fluid would help any. I may change mine before the snow, mine was bought with the intention of driving year round.
| DAMN I'M HOOKED | Touge Monster | Tracking / Autocross / HPDE / Drifting | 0 | 12-26-2012 03:46 PM |
| GGGRRRR Damn it!!! | NMMI89 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 11-11-2012 09:38 AM |
| Damn you Blizzard! | denkigrve | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 05-31-2012 03:17 PM |
| Damn Raccoons! | WRXGuy1 | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 05-27-2012 09:54 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
