Old 05-16-2014, 06:13 PM   #1
The86Ghost
Drives: 2014 FRS (Whiteout)
Pedal and Steering wheel Lock Up
so i was drifting my frs today and spun out maybe about three times in total and on the third time the steering wheel locked up and the gas pedal didnt work. Also all the hud on the dash was lit up such as check engine check oil and a few others. So i shut off the car and turned it back on and it was fine. Any ideas as to why this happened?
The86Ghost is offline   Reply With Quote
Old 05-16-2014, 06:38 PM   #2
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
That's not good at all. The electric steering does overheat if you use it too much and get harder to turn, but it won't lock up.
subiestyle is offline   Reply With Quote
Old 05-16-2014, 06:48 PM   #3
The86Ghost
yeah but it wasnt hard to turn it just locked up once i stopped spinning and moving i beleive it is like when it happens after you turn the engine off and try to turn the wheel and it locks. thats how it felt. i think the ecu or engine may have cut off for a split second causing that to happen
Old 05-16-2014, 06:58 PM   #4
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I doubt there is anything wrong with the car.
Old 05-16-2014, 07:00 PM   #5
The86Ghost
i think the same. it drove completely fine afterwards. i was just wondering why it happened
Old 05-16-2014, 07:03 PM   #6
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
sounds like you stalled out at some point during the spin.
Old 05-16-2014, 07:04 PM   #7
The86Ghost
Exactly what i think
Old 05-16-2014, 07:04 PM   #8
tahdizzle
So elite I'm 1338
These car's don't fuel starve...
Unless you can re-create it, it could be many things.
Old 05-16-2014, 07:31 PM   #9
Ozzman
Drives: old
He stalled out because the car was trying to go backwards while it was in a foreward gear with the clutch engaged.
Ozzman is offline   Reply With Quote
Old 05-16-2014, 07:54 PM   #10
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
but he said: "So i shut off the car and turned it back on and it was fine" that sounds like the car was still running, unless it stalled in the spin, but then roll-started itself again at the end of the slide.
Old 05-16-2014, 08:28 PM   #11
The86Ghost
yeah i believe this is what happened. but im not sure if the engine was still on either way it definatily stalled
Old 05-16-2014, 09:28 PM   #12
Lavalover
Drives: 2014 FR-S Monogram Hot Lava
As you are spinning out, it's better to disengage the clutch to avoid this problem. (One more thing to think about though lol).
Lavalover is offline   Reply With Quote
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 05:59 PM
Quick Release or Quick Lock Steering Wheel and Theft defense too? 1086 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-24-2014 04:50 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
New Cusco Items - Steering Wheels and Pedal Extension RallySport Direct Interior Parts (Incl. Lighting) 15 02-22-2013 01:58 PM
WTB: Steering Wheel Lock for Anti-Theft 86 FRS Miscellaneous 0 11-06-2012 05:38 PM
