Drives: 86
CEL thrown: P0073
I searched the forums, and couldn't find anyone else with this CEL. I was cruising at 45mph, no load on the engine, and the CEL just popped up.
P0073: Ambient Air Temperature Sensor Circuit High (See Update below) I have an Innovate supercharger with Delicious Tuning tune. Has anyone else experienced this? I went ahead and reset the code for now, and it hasn't popped back up. Looking at this CEL on other car forums, seem to indicate the sensor needing to be replaced. Thoughts? UPDATE: I believe I misinterpreted the code. My P3Cars gauge showed C073, and I assumed it was P0073. I'm now finding that it's actually U0073. Last edited by TemeCal; 05-15-2014 at 04:31 PM. Reason: Changed CEL code from P0073 to U0073 |
Drives: 86
Just found this post:
http://www.ft86club.com/forums/showp...00&postcount=5 @1Cor10:23 - Have you got this CEL before? It sounds like it was a simple BT communication issue for you? |
#3 | |
Drives: 2014 BRZ Limited
P0073 is a different code for ambient air temperature sensor. OP, are you certain it was P and not U? The Torque code is pretty common. |
#4 | |
Drives: 86
So, I think I misinterpreted the C073 error.
#5 | |
If you forget to shut off Torque, just use Torque to clear the code. I'm amused by the fact that the tool you use to clear it is the tool that causes it in the first place. |
#6 | |
Drives: 86
Thanks again for the help. I feel like an idiot for not realizing the code was in hexadecimal. |
| Help - Two Codes Thrown | jpit | Engine, Exhaust, Transmission | 3 | 04-20-2013 12:52 AM |
| Need Help - 2 codes thrown | jpit | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 12:41 AM |
| Bottle thrown at FR-S | L3P47 | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 12-27-2012 12:17 PM |
