Drives: Toyota 86 13'
Hi Guys,
I'm having issues connecting with my OFT atm. I keep getting "Error 0x63 while communicating with the device" To sum up everything thats happened (in order): - Flashed the car to "Stg1 A01G" - Connected to the PC/Laptop then went into "Upload" removed each file then replaced them with 1.59 (A01G) variants - Connected it back to the car and was told "Tuning file mismatching. ECU write denied" - Connected it back to the PC to see if I could reverse the issue but haven't had any luck connecting, I keep running into "Error 0x63 while communicating with the device". Tried it over a total of 3 different PCs with no luck Has anyone come across this?
Drives: 2013 BRZ Premium 6MT
there is a newer open flash manager out. its 1.07.1 not sure if it will help with your issue at all, but worth a try.
2013 Subaru BRZ Premium 6MT -STOCK!
Drives: 2013 Argento FR-S
This happened to me once. In my case, it was due to me deleting one of the ROMS. If I remember correctly, I had to flash back to stock, reset the OFT, & start over.
Sent from my XT912 using Tapatalk |
#5 | |
So I've actually lost the ability to flash and change ROMs lol |
Yeah, I've shot an email to the guys a couple of days ago. Just waiting for a reply.
Was hoping to get E85 up and running this Friday, but i'm in no rush... it's practically Winter at the moment |
#10 | |
#11 |
See if this works - Quote:
Originally Posted by Terrapin77 View Post I just tried to flash a new map, but my OFT says it can't write due being out of sync. Any ideas on how to fix this? Yes this happened to me. This is a quote from Shiv "That error occurs when you delete the map that you were previous running. For example, if you were running map bank 4 and then you delete it and only load maps in bank 1, 2 and 3. Simple fix: just load maps in each of the 5 map banks and you'll be good to go." |
#12 | |
I keep running into "Error 0x63 while communicating with the device" every time I click on "Download Data" or "Upload Data" |
#13 | |
Drives: 2013 FRS
![]() Cheers, shiv |
#14 | |
| I've fixed my Bluetooth connection issue! | Superhatch | Issues | Warranty | Recalls / TSB | 34 | 04-15-2015 02:15 AM |
| USB / Aux connection | Sporran | Electronics | Audio | NAV | Infotainment | 9 | 04-20-2014 06:22 AM |
| FRS iphone 5s bluetooth connection issue | Gank61 | Electronics | Audio | NAV | Infotainment | 2 | 04-03-2014 09:19 AM |
| FRS 28 pin stereo connection | Sparky fire | Electronics | Audio | NAV | Infotainment | 2 | 02-07-2014 03:32 PM |
| USB connection | ScottKR | Electronics | Audio | NAV | Infotainment | 5 | 07-30-2013 12:54 PM |
