Old 05-06-2014, 10:14 AM   #1
tnle
Drives: Toyota 86 13'
Post OFT - Connection Issue
Hi Guys,
I'm having issues connecting with my OFT atm.
I keep getting "Error 0x63 while communicating with the device"
To sum up everything thats happened (in order):
- Flashed the car to "Stg1 A01G"
- Connected to the PC/Laptop then went into "Upload" removed each file then replaced them with 1.59 (A01G) variants
- Connected it back to the car and was told "Tuning file mismatching. ECU write denied"
- Connected it back to the PC to see if I could reverse the issue but haven't had any luck connecting, I keep running into "Error 0x63 while communicating with the device".
Tried it over a total of 3 different PCs with no luck
Has anyone come across this?
tnle is offline   Reply With Quote
Old 05-06-2014, 05:19 PM   #2
Lytheum
Drives: 2013 BRZ Premium 6MT
there is a newer open flash manager out. its 1.07.1 not sure if it will help with your issue at all, but worth a try.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 05-06-2014, 10:38 PM   #3
tnle
Tried it this morning, no luck
Old 05-07-2014, 08:34 AM   #4
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
This happened to me once. In my case, it was due to me deleting one of the ROMS. If I remember correctly, I had to flash back to stock, reset the OFT, & start over.
Sent from my XT912 using Tapatalk
Terrapin77 is offline   Reply With Quote
Old 05-07-2014, 10:21 AM   #5
tnle
I've deleted and replaced mine with 1.59 variants, tried to flash and ran into this.
So I've actually lost the ability to flash and change ROMs lol
Old 05-07-2014, 10:30 AM   #6
steve99
Drives: FT86
Won't even write the stock rom back ??
Old 05-07-2014, 11:10 AM   #7
tnle
Yeah, I can't get past "Tuning file mismatching. ECU write denied".
Old 05-07-2014, 11:24 AM   #8
steve99
Drives: FT86
Hmmm sounds like you will have to contact the oft guys , sound like data is corrupted.
Old 05-07-2014, 11:30 AM   #9
tnle
Yeah, I've shot an email to the guys a couple of days ago. Just waiting for a reply.
Was hoping to get E85 up and running this Friday, but i'm in no rush... it's practically Winter at the moment
Old 05-07-2014, 12:53 PM   #10
steve99
Drives: FT86
I reckon they are probably all drinking E85 (or better) at Shiv's wedding
Old 05-07-2014, 04:46 PM   #11
Terrapin77
Terrapin77's Avatar
See if this works - Quote:
I just tried to flash a new map, but my OFT says it can't write due being out of sync. Any ideas on how to fix this?
Yes this happened to me. This is a quote from Shiv
"That error occurs when you delete the map that you were previous running. For example, if you were running map bank 4 and then you delete it and only load maps in bank 1, 2 and 3.
Simple fix: just load maps in each of the 5 map banks and you'll be good to go."
Old 05-07-2014, 05:07 PM   #12
tnle
The only problem is, I can't connect to my Tablet.
I keep running into "Error 0x63 while communicating with the device" every time I click on "Download Data" or "Upload Data"
Old 05-07-2014, 05:14 PM   #13
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
We will have to see what you did and then sort it out remotely. Can you please go the Download LOG section of OF Manager (with OFT connected) and press START. This will generate a rather large (~5mb) file that you can email to me at shiv@vishnutuning.com. I can send it to the programmers and they can sort it out somehow
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post:
BabaYaga (06-27-2021), tnle (05-07-2014), Turdinator (05-07-2014), wparsons (05-09-2014)
Old 05-07-2014, 05:35 PM   #14
tnle
Cheers,
shiv
I've sent it through, thanks!
The Following User Says Thank You to tnle For This Useful Post:
Shiv@Openflash (05-07-2014)
I've fixed my Bluetooth connection issue! Superhatch Issues | Warranty | Recalls / TSB 34 04-15-2015 02:15 AM
USB / Aux connection Sporran Electronics | Audio | NAV | Infotainment 9 04-20-2014 06:22 AM
FRS iphone 5s bluetooth connection issue Gank61 Electronics | Audio | NAV | Infotainment 2 04-03-2014 09:19 AM
FRS 28 pin stereo connection Sparky fire Electronics | Audio | NAV | Infotainment 2 02-07-2014 03:32 PM
USB connection ScottKR Electronics | Audio | NAV | Infotainment 5 07-30-2013 12:54 PM
