CANADA Canada
Old 04-16-2014, 04:36 PM   #1
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Camber bolt
Hello guys.
I lowered 1" mine with Eibach Pro kit but my rear wheels seems to be cambered but not in the front, is it normal behavior?
sorry for the noob question.. Im asking this because I got my 18x8.75 xxr 527 all around but front poke out too much compare to the rear.
If I want to buy them where should I go?
Thanks in advance.
bhbnuckle is offline   Reply With Quote
Old 04-16-2014, 04:43 PM   #2
ayau
Drives: Some rust bucket
Originally Posted by bhbnuckle View Post
Hello guys.
Thanks in advance.
It's normal due to the front and rear suspension design. The front is a MacPherson strut and the rear is multi-link design.
You have a couple of options as far as camber bolts for the front.
-OEM crash bolt (can buy at Subaru or Toyota)
-SPC camber bolt
-Whiteline camber bolt
I believe Whiteline is just the SPC camber bolt but rebranded. SPC/Whiteline may get you a little more camber (maybe 2 tenths), but they rust a lot quicker. I opted for OEM bolts.
The Following User Says Thank You to ayau For This Useful Post:
bhbnuckle (04-16-2014)
Old 04-16-2014, 04:50 PM   #3
bhbnuckle
bhbnuckle's Avatar
-SPC camber bolt
Should I install them at the Shop or its DIYable?
Thank you..
Old 04-16-2014, 08:05 PM   #4
Steve
Steve's Avatar
Drives: 6MT
You could install them yourself... but to get a specific amount of camber out of them you should get an alignment. Most shops that do alignments will put them on for you in a couple minutes and then they can dial them in with the alignment.
Steve is offline   Reply With Quote
The Following User Says Thank You to Steve For This Useful Post:
Camber Bolt Help Please! ft86Fan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 114 02-27-2019 11:13 AM
Camber bolt on KW V3 derek1ee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-25-2017 11:21 AM
Whiteline Camber bolt.... Help FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 04-28-2017 03:15 PM
Camber bolt help oofie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-22-2013 01:36 PM
