Old 05-03-2014, 09:16 PM   #1
jdmblood
jdmblood's Avatar
Drives: white subaru brz
difference in offsets
looking at enkei pf01s in 17x8. My two choices for offsets are +48 or +35. If I'm not mistaken, the 35 offset would poke more than 48. Would it be a noticeable difference? I'm wanting to get a flush look on the car so would the 48 require spacers to get a flush look. Lowered on h&r super sport springs. Thanks in advance!
jdmblood is offline   Reply With Quote
Old 05-03-2014, 09:18 PM   #2
gramicci101
Off Topic
This thread will tell you. Check posts two and three.
http://www.ft86club.com/forums/showthread.php?t=7535
Old 05-03-2014, 09:35 PM   #3
jdmblood
jdmblood's Avatar
the link to the 35 offset doesn't have a pic from the side to compare. Also curious as to how the 1.4 inch drop compares to just a 1 inch drop.
Old 05-03-2014, 09:56 PM   #4
gramicci101
Off Topic
According to the charts, +35 will be 1mm past flush at a 1" drop, so it'll probably be fine for a 1.4" drop. You could actually run the +35 with a 5mm spacer in the back to bring it out to just under flush at a 1" drop.
Don't look at the links first, look at the proximity to the grey and yellow stars. Then look at the links.
Old 05-03-2014, 10:06 PM   #5
jdmblood
jdmblood's Avatar
oh never thought of that. I'm more interested in the 48 offset because they are available on tirerack which I trust more. Tirerack does not have the 35 offset. The 48 offset would be more sunken in than the 35? If I'm not mistaken the 17x8 +48 pf01 would poke more than stock due to the extra width or is that a false assumption?
Old 05-03-2014, 10:21 PM   #6
gramicci101
Off Topic
@FT-86 SpeedFactory has the +35 offset. They're very highly regarded on this forum, with a lot of member reviews. Plus, they offer free shipping on purchases over $250 and they throw candy in the box.
A 17x8 +48 will stick out an extra inch over the OEM 17x7 +48. The offset (+48) is measured from the mounting surface to the inner edge of the wheel. So if that stays the same between the two wheels, the inner edge will stay the same in relation to the suspension and the additional inch will have to be on the outer edge, effectively sticking out an inch beyond the OEM wheel.
The +48 wheel could be run with a 10mm spacer, making the effective offset +38. I'd just get the +35 and call it a day. For the back, you could get a 5mm spacer instead of a 15mm spacer. Spacers above 10mm or so get expensive because of the need for longer or additional studs.
Old 05-03-2014, 10:31 PM   #7
jdmblood
jdmblood's Avatar
what if I run the 48 offset without any spacers at all? Ft86speedfactory has rpf1s, not pf01s.. Thank you for the quick replies
Old 05-03-2014, 10:39 PM   #8
gramicci101
Off Topic
If you run +48 with no offsets it'll look a little less sunken in than the OEM wheels, but not by much. You'd need spacers to get a decently flush look to the car.
Also, search the vendor classifieds for PF01. There are a few forum vendors that carry them, in both offsets. It looks like @OAKOS Automotive sells them here. With free shipping. Although apparently with a +45 offset.
The Following User Says Thank You to gramicci101 For This Useful Post:
OAKOS Automotive (05-06-2014)
Old 05-03-2014, 11:28 PM   #9
jdmblood
jdmblood's Avatar
the 38s wouldn't require a spacer?
Old 05-04-2014, 12:01 AM   #10
gramicci101
Off Topic
The +38s are a 17x7.5. That's flush at a +29 offset at a 1" drop. So probably a 10mm spacer for a 1.4" drop. In the front.
What size tires are you looking to run?
Old 05-04-2014, 07:52 AM   #11
jdmblood
jdmblood's Avatar
meant to say +35 in my last post. 17x8 +35. Which tire should I run on a 17x8 rim?
Old 05-04-2014, 08:17 AM   #12
diss7
Drives: AE86, 2x GT86, TE27
17x8 +35 looks good.
Tyre wise, depends on what you want to achieve. 235/40 seems like the most popular choice for that rim.
Personally, I run 205/40 on 8's. Because drift.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
jdmblood (05-04-2014)
Old 05-04-2014, 08:21 AM   #13
jdmblood
jdmblood's Avatar
ok 235/40. And I like turtles too. I'm going to try to find a vendor that I trust to purchase the 35s from.
Old 05-05-2014, 05:18 PM   #14
jdmblood
jdmblood's Avatar
i spoke to a salesman on tirerack and he informed that the +35 offset are actually in stock in a 17x8 pf01. yet he did not sound too assuring that they would fit i dont know why. is the 17x8 +35 pf01 lowered on h and r super sport springs a safe bet?
WTB: Volk TE37 Conservative Offsets Tweaksalot Want-To-Buy Requests 1 05-01-2014 11:48 AM
cat/no cat hp difference? EN2_Squirrel Engine, Exhaust, Transmission 6 11-17-2013 09:32 PM
Every difference between the MT and AT BlueDubbinTDI Engine, Exhaust, Transmission 38 09-04-2013 09:32 AM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
