Old 05-01-2014, 03:50 PM   #1
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
tom's tail lights issue
i installed my tail lights and got the flasher installed also and when i use the left turn signal it does not work at all..also when i push the emergency lights same thing..only the right side works. I sent the video of it happening to RavSpec which i purchased the lights from. Not much help except that they would contact Depo and let me know but this was yesterday morning. anyone else had this issue?
FRS-HHH is offline   Reply With Quote
The Following User Says Thank You to FRS-HHH For This Useful Post:
ayetothejay (05-02-2014)
Old 05-01-2014, 05:50 PM   #2
Skurj
Drives: SOLD...
These USDM Tom's? or JDM's requiring re-pinning? Guessing they are USDM. Sounds like you may have a defective unit..
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 05-01-2014, 07:10 PM   #3
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
US DOT approved models are straight plug & play. He may have the JDM spec ones.
MokSpeed is offline   Reply With Quote
Old 05-01-2014, 07:32 PM   #4
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
yes USDM
Old 05-01-2014, 07:32 PM   #5
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
USDM ...these are straight plug and play ..the right tail light works like a charm..my left when i press the brakes the light comes on but blinker wont come on at all or even show in the dash thats the left blinker is on.
Old 05-01-2014, 07:56 PM   #6
accelerated
Drives: Scion FR-S
Try reinstalling your original flasher relay and see if it works then. Might have gotten a bad one.
accelerated is offline   Reply With Quote
Old 05-01-2014, 08:12 PM   #7
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Just ordered a set of USDM Tom's tailights last weekend.
They will be deliveried this Friday.
I tried soooooooooooooooo hard not to open this thread.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following User Says Thank You to Figo For This Useful Post:
JustBoostin (05-06-2014)
Old 05-02-2014, 01:35 AM   #8
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
Im at work but I will try it in the AM . Its just weird that the right works and not the left. So far ravspec ain't doing much to help with the issuebut we will see if they get back at me sometime soon.
Old 05-02-2014, 02:33 AM   #9
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Like everybody else said, try the original flasher relay with the bad tail light, or you could also try the new flasher with the OEM tail light, make sure the that works. Doing both would be a good double check to see if the problem is with the relay or the tail light itself.
cdo221 is offline   Reply With Quote
Old 05-02-2014, 02:52 AM   #10
BRAWL
Drives: Toyota 86 GTS Velocity Orange
Also just double check the connection at the right hand light and make sure it is not something silly like the plug is not pushed in all the way
BRAWL is offline   Reply With Quote
Old 05-02-2014, 08:14 AM   #11
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
I did do that same issue. I havenot used the original oem flasher though I will try that today.
Old 05-02-2014, 07:23 PM   #12
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
tried it and it still didnt work. but the original flasher works with my oem tail lights . Ravspec told me to pack them up and ups will pick them up so i can get them replaced.
Old 05-02-2014, 07:53 PM   #13
BRAWL
unlucky mate, probably something slighty miswired from factory. Only one I have heard of to date
Old 05-02-2014, 10:31 PM   #14
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
Yah probably..but hope to get the new ones in soon
TOM'S Racing JDM LED Tail Lights , Spyder LED Tail Lights, and JDM Side Markers!! Evasive Motorsports Exterior Parts - Lighting 94 12-18-2015 01:19 PM
FS/FT RED TOM'S LED USDM DOT Tail Lights FOR CLEAR TOM's LED Tail Lights giants130 Exterior Parts (Aero, Lighting, Etc.) 4 04-28-2014 06:41 AM
WTT - My Vertex tail lights for Crystal eye tail lights drftxx Exterior Parts (Aero, Lighting, Etc.) 0 02-19-2014 10:34 PM
TAIL LIGHT CRACKING ISSUE TSB... 5AD86D Issues | Warranty | Recalls / TSB 0 12-18-2013 01:53 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
