Drives: Whiteout FRS
Racer X toe arms
Anyone install these yet? I searched to see if anyone did a how too, but no luck with that. If you have can you PM' me or point me in the right direction.
life's greatest stories usually start with the words, "fuck it!".
Because compromise ®
Drives: Red Herring
I have them fitted. They should be fitted at a alignment shop unless you can do alignments at home. The actual installation is so straight forward they don't require a "how to".
Drives: '24 GR86
Remove OEM links. Install new ones. Take to alignment shop.
Done
They're forgetting the most important part. Make sure you have a Pitmann arm puller or else you're going to have a hell of a time. Also, be careful driving, it's very dangerous installing these plus LCA's at the same time then getting to an alignment shop.
Sincerely, Whiteline toe arm installer. |
Installing at hobby shop on base and they have a hunter something something alignment machine there. The thing I was asking about was the spacers on the part that attaches to the knuckle...I am not that much of an idiot i know its unbolt then bolt on the new just some small stuff i didn't know
| DME Lower Control Arms and DME Toe Arms - Review | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 02-24-2015 11:53 AM |
| New Racer X Fabrication rear lower control arms! | Jeff@Racer X Fab | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 36 | 04-28-2014 05:56 AM |
| Racer X fabrication rear suspension arms | jah29 | Brakes, Suspension, Chassis | 4 | 04-06-2014 08:43 PM |
| Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! | Jeff@Racer X Fab | Brakes, Suspension, Chassis | 25 | 01-24-2014 11:42 AM |
| GTSPEC rear control arms & toe arms review | Jesse | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 08-23-2013 03:20 PM |
