Mishimoto question
Hey guys, quick question. If I replace my FR-S OEM radiator for a Mishimoto one and then add a Mishimoto oil cooler, will this leave space to add a turbo inter cooler later on? Thank you!
V/r Sef |
You should have no problem.
Drives: Asphalt FRS
Yes. I have the Mishimoto radiator with our turbo kit, and it fits well
Drives: Asphalt FRS
Drives: frs
is an oil cooler ok for winter tho?
#7 | |
Drives: 2013 Subaru BRZ
We have received numerous requests for a kit with cooler mounting that functions with a FMIC. Absolutely. For NY winters I would recommend utilizing our kit with thermostatic sandwich plate. This will ensure that the oil reaches proper operating temperature in a timely fashion. Our sandwich plate is set to activate at 185°F, but we have additional temperature thermostats as well. Let me know if you have any questions, I would be happy to help.
#8 | |
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Thank you |
#9 | |
Unfortunately the FA20 engine oil filter housing is a unique setup and will not allow for the use of a standard style sandwich plate by itself. Please reference the image below! ![]() The spacer you see on the bottom is CNC'd from billet aluminum and raises the sandwich plate above the lip of the oil filter housing. The housing has a cup-like top which collects residual oil when the filter is removed. Check it out below. ![]() So the first components is a spacer which raises the sandwich plate above this lip so it fits correctly. On top of the sandwich plate we utilize our own cup-like CNC component which emulates the responsibilities of the one from the factory and prevents the spill of oil during a filter swap. It is because of these CNC components that we highly recommend the direct-fit kit. Additionally, we include a direct-fit bracket for the BRZ/FR-S which securely mounts the cooler in a location with great airflow for optimal cooling efficiency. Let me know if this adequately answers your questions. We also have some of our product samples here in the office if you would like any specific images of a particular component. Thanks |
| Mishimoto Radiator & Blue Mishimoto Hose Kit | tlinspired830 | Engine, Exhaust, Bolt-Ons | 6 | 03-24-2014 10:34 PM |
| Mishimoto Radiator & Mishimoto Radiator Hose Kit | tlinspired830 | Engine, Exhaust, Bolt-Ons | 5 | 01-08-2014 08:44 AM |
| Mishimoto Radiator | Alfalasy | Engine, Exhaust, Transmission | 32 | 11-25-2013 02:51 PM |
| Mishimoto on TV! | Mishimoto | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 10-07-2013 04:39 PM |
| Hello from Mishimoto! | Mishimoto | Announcements, Contests, Giveaways | 12 | 07-05-2012 06:18 PM |
