Old 04-27-2014, 09:13 AM   #1
afsefo
afsefo's Avatar
Mishimoto question
Hey guys, quick question. If I replace my FR-S OEM radiator for a Mishimoto one and then add a Mishimoto oil cooler, will this leave space to add a turbo inter cooler later on? Thank you!
V/r
Sef
afsefo is offline   Reply With Quote
Old 04-27-2014, 09:32 AM   #2
mike the snake
You should have no problem.
Old 04-27-2014, 09:54 AM   #3
MAPerformance
Drives: Asphalt FRS
Yes. I have the Mishimoto radiator with our turbo kit, and it fits well
MAPerformance is offline   Reply With Quote
Old 04-27-2014, 11:33 AM   #4
afsefo
afsefo's Avatar
Do you have the oil cooler sandwich between the radiator and turbo inter cooler? or you changed the location of the oil cooler?
Old 04-27-2014, 03:58 PM   #5
MAPerformance
Drives: Asphalt FRS
It is for now, but we are going to try another place, possibly with a fog light vent or something.
Old 04-28-2014, 03:25 AM   #6
supradoopra
Drives: frs
is an oil cooler ok for winter tho?
supradoopra is offline   Reply With Quote
Old 04-28-2014, 11:28 AM   #7
Mishimoto
Drives: 2013 Subaru BRZ
Thank you! Fighting for front bumper real estate is a real challenge at times, especially when you have multiple aftermarket heat exchangers. I appreciate the fitment confirmation.
We have received numerous requests for a kit with cooler mounting that functions with a FMIC.
Absolutely. For NY winters I would recommend utilizing our kit with thermostatic sandwich plate. This will ensure that the oil reaches proper operating temperature in a timely fashion. Our sandwich plate is set to activate at 185°F, but we have additional temperature thermostats as well.
Let me know if you have any questions, I would be happy to help.
Mishimoto is offline   Reply With Quote
Old 04-28-2014, 10:40 PM   #8
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Could you please explain the differences between your universal kits and the FRS/BRZ specific kits? Specifically the necessity of the spacers for the sandwich plate?
Thank you
Whatabouteggs is offline   Reply With Quote
Old 04-29-2014, 09:46 AM   #9
Mishimoto
Thank you
Absolutely! In a normal circumstance, one can purchase our universal kit and make it function just like our direct-fit units with a little extra work. This requires modifying the lines and developing/fabricating an oil cooler mounting bracket.
Unfortunately the FA20 engine oil filter housing is a unique setup and will not allow for the use of a standard style sandwich plate by itself. Please reference the image below!
The spacer you see on the bottom is CNC'd from billet aluminum and raises the sandwich plate above the lip of the oil filter housing. The housing has a cup-like top which collects residual oil when the filter is removed. Check it out below.
So the first components is a spacer which raises the sandwich plate above this lip so it fits correctly. On top of the sandwich plate we utilize our own cup-like CNC component which emulates the responsibilities of the one from the factory and prevents the spill of oil during a filter swap.
It is because of these CNC components that we highly recommend the direct-fit kit. Additionally, we include a direct-fit bracket for the BRZ/FR-S which securely mounts the cooler in a location with great airflow for optimal cooling efficiency.
Let me know if this adequately answers your questions. We also have some of our product samples here in the office if you would like any specific images of a particular component.
Thanks
Mishimoto Radiator & Blue Mishimoto Hose Kit tlinspired830 Engine, Exhaust, Bolt-Ons 6 03-24-2014 10:34 PM
Mishimoto Radiator & Mishimoto Radiator Hose Kit tlinspired830 Engine, Exhaust, Bolt-Ons 5 01-08-2014 08:44 AM
Mishimoto Radiator Alfalasy Engine, Exhaust, Transmission 32 11-25-2013 02:51 PM
Mishimoto on TV! Mishimoto Off-Topic Lounge [WARNING: NO POLITICS] 2 10-07-2013 04:39 PM
Hello from Mishimoto! Mishimoto Announcements, Contests, Giveaways 12 07-05-2012 06:18 PM
