Old 04-25-2014, 07:44 PM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Arrow SPED D HEADLIGHTS W/ HID DIODE DYNAMICS WORK?
Hey guys im getting the Spec D headlights for our FRS and i want the HID option but im looking into DIODE DYNAMICS HIDs. Will their H1 HID Kit work with our cars? i have HIDS now but can i just get swap the bulb to an H1 bulb? not sure how that works.
Hope Someone Can Give Me Some Insight! THANKS !
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 04-26-2014, 12:25 AM   #2
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
You should be able to swap just the bulbs and keep using the ballast.
Chen is offline   Reply With Quote
Old 04-26-2014, 09:53 AM   #3
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
H1s will work but D2S bulbs are the perfect fit solution. With H1 bulbs you have to use washers and try to center the light. The D2S bulbs are a direct fit eliminating the need to play with washers for fitment.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 04-26-2014, 12:22 PM   #4
ScionFR-S
ScionFR-S's Avatar
I think the winjets may be a better choice for me personally... Less problems and they have been out for a while which eliminate the technical erros the spec d may have
Old 04-26-2014, 12:52 PM   #5
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Whatever works for you. I have both. I've experienced no issues with the spec d lamps unless you have a front mount intercooler.
Old 04-26-2014, 03:15 PM   #6
ScionFR-S
ScionFR-S's Avatar
I thought they weren't released yet.
Old 04-26-2014, 03:18 PM   #7
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
They've been released for nearly a month
FS: Diode Dynamics 6k HID kit MrMarinakos Exterior Parts (Aero, Lighting, Etc.) 3 05-07-2014 04:53 AM
. Selvedge Canada Classifieds 5 04-27-2014 09:30 PM
Diode Dynamics HID Kit Issues austin_kw Cosmetic Modification (Interior/Exterior/Lighting) 7 03-19-2014 04:32 PM
DIY - Diode Dynamics HID install on WinJet/Spyder Headlights FT-86 SpeedFactory DIY (Do-It-Yourself) Guides 0 02-21-2014 09:57 AM
Diode Dynamics Fog Kit skyre User/Vendor/Sponsor Reviews, Feedback, Comments 1 12-23-2013 12:29 PM
