Old 04-24-2014, 09:04 PM   #1
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
clutch dilema
Ok so my car is making too much power for the stock clutch at the moment. I need something that is going to handle 350-400 wtq.
I was looking at the ACT 4 puck rated at 375 wtq I believe
or
Exedy stage1 or stage2
many people have said the Exedy clutch is underrated.
cjsporl1996 is offline
Old 04-24-2014, 09:08 PM   #2
STV3
Señor Member
STV3's Avatar
Have an act 6 puck in my other car for quite a few years now and love it. Still hasn't slipped on me yet. Car has over 400lbs of torque to the wheels
STV3 is offline
Old 04-24-2014, 09:18 PM   #3
cjsporl1996
@CSG Mike
Old 04-25-2014, 07:46 AM   #4
cjsporl1996
Bump
Old 04-25-2014, 11:35 AM   #5
Pneub
Drives: Dark Grey BRZ
Exedy stage 1 is only rated to 205 and I think the stage 2 is 230.
Pneub is offline
Old 04-25-2014, 11:48 AM   #6
Brick
Drives: White 2013 FRS
If it's a street driven car I wouldn't get a 6 puck WITH a super light flywheel. Before everyone jumps on the be a man deal with the clutch bandwagon remember it's not always you who is gonna be driving your car. What happens when you have to give the keys over to a shop owner to drive it up on the dyno? Or valet parking, plus by having a clutch you can't purposefully slip you are putting more shock loading on your drivetrain. Just good for thought.
Brick is offline
Old 04-25-2014, 12:08 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Exedy stage one is underrated. It can handle way much more than what its rated for as Ptuning has found out.
I run CM FX400. Goo reputation company, clutch holds power. I would go for it.
Sportsguy83 is offline
Old 04-25-2014, 12:36 PM   #8
STV3
Señor Member
STV3's Avatar
I've had two bad experiences with CM clutches. First one had a spring pop out and the second only lasted about 10k miles before it started to slip and my car was with in the advertised Tq limit.
These were street disks though not pucked so it maybe their pucked clutches are better.
STV3 is offline
Old 04-25-2014, 04:51 PM   #9
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Why is no one asking him how he plans on making that much torque from the vortech kit?
"350-400 wtq."
The highest Wtq I have seen for vortech kits is fluttering around 260...
SkAsphalt is offline
Old 04-25-2014, 06:07 PM   #10
cjsporl1996
"350-400 wtq."
I've been working on a secret project. It's not done yet but I will be releasing some info in about 2 weeks.
Old 04-25-2014, 06:08 PM   #11
cjsporl1996
Ended up going with the competition clutch stage 3
act, clutch, exedy
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
