Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > Hawaii
Hawaii Aloha!
Old 04-23-2014, 07:41 PM   #1
kailuaboy808
Drives: black scion frs
need help with rim size
I'm getting rims that are 18 x 9.5. What is a better offset 32 or 44. I don't want the wheels to stick outside the fender.
kailuaboy808 is offline   Reply With Quote
The Following User Says Thank You to kailuaboy808 For This Useful Post:
ZionsWrath (04-24-2014)
Old 04-23-2014, 08:33 PM   #2
congiiee
Drives: WRB Subaru BRZ
I would go for 44 definitely. From experience with stock suspension and camber you will have a slight poke outside fender.
congiiee is offline   Reply With Quote
The Following User Says Thank You to congiiee For This Useful Post:
Old 04-24-2014, 02:08 AM   #3
brz_star21
Drives: DGM BRZ
Stock type suspension or coilovers? I would stay away from the +32 if you don't like the fender poke. Just be careful with +44 as it may rub on the inside (assuming still stock type setup) and depending on tire size. Are those the only offsets available in the rim you want?
brz_star21 is offline   Reply With Quote
The Following User Says Thank You to brz_star21 For This Useful Post:
Old 04-24-2014, 02:15 AM   #4
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
+44 cause concave is legit.
Chen is offline   Reply With Quote
The Following User Says Thank You to Chen For This Useful Post:
Old 04-24-2014, 02:20 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
Even with 44 still going to poke
Old 04-24-2014, 03:52 PM   #6
Hayashi
Hayashi's Avatar
Buy my rims!!!! lol. In all seriousness though it all depends on what type of suspension you have. If you're stock, +44 is going to be super close to hitting. +40 is pretty darn close. I don't think you could stick a finger underneath.
Also, if you do have coilovers. You could still get +32 and have no poke, just depends on your camber settings haha.
Hayashi is offline   Reply With Quote
Pad Size Help swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-01-2013 08:13 AM
BRZ USB Max Size ShaunNeutron Electronics | Audio | NAV | Infotainment 16 05-09-2013 02:55 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
Lug size Chewie4299 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-06-2012 12:32 AM
