Drives: Raven FRS
10 series headlights into frs
Hey guys I have followed the DIY available and other threads, what I did was repin the wires into the frs harness. all (6 wires). Also unplugged the DRL resistor. but the DRL does not light up during the day, only when the lights are turned on for the night the led strip and HID turn on. I'm not sure what wiring I've missed.
Please help me! Thanks |
Drives: Whiteout FRS
If I'm reading this right, to get the DRL to work you only unplugged the resistor? You also need to run a wire from the DRL fuse to the pin which powers the LED. The 6 pins will only turn it on with parking lights and headlights on.
Edit: see this thread: http://www.ft86club.com/forums/showthread.php?t=60073 |
Drives: Asphalt FRS
So the LED strips are only turning on with Parking lights and Highbeam? Low beam as well?
Drives: Raven FRS
#5 | |
Drives: Raven FRS
I don't know the setup for the10 series, but it would be whichever pin corresponds to the parking+ wire in the frs harness (pin 6)
Drives: Asphalt FRS
Would it just be possible to remove the Parking+ Wire pin from the FRS side harness and draw power from the 12V where the resistor on the passenger side used to be?
Canadian FR-S Member
Drives: FR-S '10 Series'
I thought (maybe I misread somewhere) you could put 10 Series on a regular FR-S by repinning like you've done and the DRL LEDs would work during the day.
However, the car cannot be in park or with ebrake up. That is how the 10 Series/Monograms work. |
#9 | |
Drives: Raven FRS
It doesn't light up with ebrake down and not in park |
#10 | |
My understanding is that the 10 series/monogram are wired differently, so they have a low beam, high beam wire, and then a wire which powers the LEDs as a DRL seperately. A regular FRS in its headlight harness has three power sources: Low beam, High beam, and parking (which the FRS stock lights don't actually use, but it is still there), all of which are controlled by the headlight stalk (the stock DRLs actually are the high beam halogens run at a lower voltage or something). So to get the LED to work as a DRL you must tap something which is on normally without turning the switch on the stalk, like either the DRL fuse (and unplug the resistor), or tap a 12 volt source which is always hot (like the cigarette lighter behind the glove box). |
#11 | |
Drives: Raven FRS
Yes the LED switches off when the headlights are switched on, I tried wiring it like that. |
#12 | |
1. Wire it to a constant 12 volt source when the car is on. Basically tap a power source like is done here: http://www.ft86club.com/forums/showthread.php?t=27813. If you do it this way, the lights will be on when the key is in the acc position as well, so if you are sitting in the car listening to the radio it the lights will be on too. If you want it to turn off when the ebrake is pulled, you can add a relay like I show in this post: http://www.ft86club.com/forums/showp...8&postcount=70 2. Probably an easier way to do this would be to pull the parking + pin from the harness, connect the DRL 12 volt to the back of that pin, then return the pin to the harness. This way, the DRL power will power the LED during the day, and when you turn on the headlights, the power will kick in from the parking light source. You could put a diode on the DRL wire and the parking wire to ensure each doesn't effect the other in some weird way, but I am not sure that is necessary. |
#13 |
Drives: Asphalt FRS
I'm assuming you mean this then
10 Series headlight side/FRS body side High beam + = High Beam + High beam GND = High Beam GND Low beam + = Low Beam + Low beam GND = Low Beam GND LED + = Harness pin connecting to DRL power source LED GND = Parking GND Nothing = Loose Parking + pin Or did you mean to pin the Loose Parking + pin with the Harness pin connecting to the DRL source. If this is the case, I'm not exactly sure if the LED's will be handle the amount of juice its getting if you are running the DRL and Press the high beams as both sources would be providing power to the LED's. |
#14 | |
| Installed 10 Series Headlights Today | Calavera | Cosmetic Modification (Interior/Exterior/Lighting) | 58 | 02-15-2024 03:18 PM |
| Monogram/ Series 10 Headlights | fitcious | Cosmetic Modification (Interior/Exterior/Lighting) | 130 | 06-10-2016 10:07 AM |
| Scion 10 series headlights | gusbarragan | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 04-20-2014 11:26 PM |
| 10 series headlights retrofit with regular frs need help! | bdanisi | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 11-21-2013 05:37 PM |
| 86 Headlights (10 Series) $656 Each at www.onlinetoyotaparts.com YMMV | Calavera | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 08-21-2013 06:54 AM |
