Old 01-31-2013, 10:07 AM   #1
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
F-T DRL DIY
http://www.ft86club.com/forums/showthread.php?t=25959
This is the car running headlights OFF. The DRLS are on high power.
This is the car running headlights ON. The DRLS switch to low power automatically with the blue wire hooked up.
FR-Shadow is offline   Reply With Quote
The Following 8 Users Say Thank You to FR-Shadow For This Useful Post:
Captain_Awesome_Pants (03-31-2013), enouf (04-25-2013), ish20 (02-02-2013), MaXimus (01-31-2013), mezdup (01-31-2013), NSV (03-31-2013), sega_102 (01-31-2013), serial gixxer (01-31-2013)
Old 01-31-2013, 02:52 PM   #2
jwbrocloud
Drives: Raven MT
Excellent. Gotta have a set.
jwbrocloud is offline   Reply With Quote
Old 01-31-2013, 11:02 PM   #3
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Well written dude
Any change of getting more pics of the DRL from a closer vantage point?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 02-01-2013, 12:13 AM   #4
FR-Shadow
FR-Shadow's Avatar
Originally Posted by DriftEightSix View Post
Well written dude
Yeah ill try to get pictures when the car is clean.
Old 02-01-2013, 04:01 AM   #5
Ryat
Drives: Scion FRS
Looks pimp I want some now
Ryat is offline   Reply With Quote
Old 02-02-2013, 09:52 PM   #6
ish20
ish20's Avatar
Drives: 2008 Scion tC & 2013 Scion FR-S
Thanks very much for the DIY, got mine installed yesterday and followed your guide. It made it very easy!!
ish20 is offline   Reply With Quote
Old 02-04-2013, 01:22 PM   #7
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
Did I miss it? I've read it twice now & can't see who makes these?
Jared0934 is offline   Reply With Quote
Old 02-04-2013, 03:41 PM   #8
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Originally Posted by FR-Shadow View Post
DISCLAIMER** I am not held responsible for any damage to anyone's vehicle. This is how I did it and it can be done many different ways with the same result.
This is what comes in the package. I did NOT need anything else to complete installation. Maybe electrical tape but that was just to clean up the wiring
The tools I used were:
Flat head screwdriver-optional
10mm socket
scissors-for electrical tape
electrical tape-optional
zip ties-already supplied
Pandora-optional
I can start by saying you do not need to take off the front bumper or even jack up the car to get from underneath if you use this DIY.
My OEM DRLS are shut off via the ECU from the dealer.
The front plastic covers just pop off. Use your fingers or a flat head screwdriver to just pry off.
Next take the long wiring harness supplied and feed it through the passenger side behind the head light and down. You will be able to see the bottom of the bumper so seeing where the wiring goes should be easy. If you want you can also stick your hand in the hole where the new light goes and grab the wiring. I have huge hands so if my hands fit so can yours most likely.
This is what it should look like afterwords.
This is where people can choose to follow the way I did it or they can choose another way.
I wanted to feed it along the top of the bumper for easy acess if need be as well as I was afraid you would see the wire loom from the front bumper grill.
I started to feed it as so. Please see pictures below. From Passenger side to Driver's side. You will see the holes i used to zip tie the loom under the metal to hide it as much as possible as well as keep it suspended from getting into anything else.
Under the hood latch.
I have a Takeda intake and there is a small little gap under the air snorkel i fed the wires through.
Comming out of the other side.
Zip tie again.
Again push behind the Drivers headlight and down to the hole. This one you really may need to reach up with your hand to grab. There isnt much room behind the drivers side headlight.
Plug in the new DRL lights and make sure to get these three tabs in the holes right otherwise the plastic may not be full secure.
Finished result of what it looks like after placed in.
Then after all the wiring is fed and zip tied where you want it back on the passengers side you will have two connectors ready to be plugged into the resistor box.
I zip tied the resistor box to the bundle of wires behind the fuse box in the engine bay. Use 4 zip ties total.
Also on the other wiring harness with:
red
blue
white
black
I cut the wiring covering to get the red wire out and rewrapped the covering onto the other wires and used tape to seal it back up.
I routed the other wires back to the headlights (front of the car) as the power wire (red) i routed to the back of the engine bay to gain access to an ignition wire.
From here this is where others can choose a different route or wite to tap. I wanted to do the ignition wire under the dash behind the cigarett outlet in the glove compartment.
Please see routing below. I may still go in and cover it up but it doesnt look bad with just one wire. its hardly noticable To get the wire inside i used the screw driver to push through a hole. Then placed the wire in and pushed it through with the screwdriver.
If any part takes you the longest it will be this next step.
To try to tap into the power wire behind the outlet is so hard you have to do it blind alot of the time just because its hard to get under there. You can always opt to drop the glove compartment to gain more access but thats all up to you.
Attach the fuse wire (supplied) and then tap into the power wire as see below.
Now back to the other wires in the engine.
This is where it gets optional again. There are 3 preferences on these. These are also listed in the instructions (supplied)
1. DRLS on all the time (only connect the red wire)
2. DRLS switch to low power when headlights come on (connect blue wire with step 1)
3. DRLS shut off when headlights come on (connect white wire)
I went for option 2 and connected the blue wire to the red power wire from the low beam of the passenger headlight.
Tear away a little of the white covering to give room and tap as so.
Then plug back in and this is what you will see.
Then take the groud wire and on the frame you will see a bolt that has a ground wire already connected. unscrew it with the 10mm and slide the ground wire over the bolt. it fits perfectly and just retighten.
Then clean all the wiring up with electrical tape if you choose to do so and tuck the wires away.
Then you are DONE! It was 15 degrees out and the car was filthy since we got 3 inches of snow lastnight.
here are some shots from about 80 ft away give or take. maybe 35 paces.
Is it possible to still have the original Drl on in the headlights while having these on? Also would you be able to take some closer images of the light when lit up and off TY
Minovsky is offline   Reply With Quote
Old 02-04-2013, 03:46 PM   #9
FR-Shadow
FR-Shadow's Avatar
Yes it is still possible. Since these are independant the OEM DRLs should have absolutely no effect.
Also I have already tinted mine with overlays but here are some close ups. Sorry I couldnt be more helpful with pictures. Its below freezing here in WI and the only option I have is to wash the car outside and this car will never see an automatic car wash.
Old 02-04-2013, 03:59 PM   #10
Minovsky
Minovsky's Avatar
that actually looks really nice @@!!!! where did you get these from? Thanks alot for the pics man!!
Old 02-04-2013, 04:04 PM   #11
FR-Shadow
FR-Shadow's Avatar
Where did i get the lights or where did i get the overlays?
Old 02-04-2013, 04:31 PM   #12
Minovsky
Minovsky's Avatar
The lights what are overlays? xD sorry noob here!!
Edit: oh are the lens part tinted"? haha i think i see it now xDD
Old 02-04-2013, 04:44 PM   #13
FR-Shadow
FR-Shadow's Avatar
And yes mine are tinted
The Following User Says Thank You to FR-Shadow For This Useful Post:
carlitosway6891 (02-27-2013)
Old 02-04-2013, 04:51 PM   #14
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
just got mine today... let the install begin! thanks for the diy
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
