Old 04-22-2014, 09:53 PM   #1
primalT
primalT's Avatar
Drives: 2014 BRZ AT
Handgun hiding spot in brz
I guess this is the best topic to post this in?
I have a 2014 BRZ. I didn't realize when buying it that the glove box didn't lock, so I currently have my handgun in a lockbox under the drive seat that is attached to the bottom of the seat frame by a cable, so it can't be stolen unless bolt-cutters are used.
The main issue is that it is 100% inaccessible which defeats the purpose of having it in there.
Missouri law requires it must be pretty well concealed if someone were to look inside my car through the windows.
Has anyone else found a solution to this?
My best thought was getting some sort of holster that hangs down from the steering wheel column, but I've only found these on google:
I need it more hidden than that, like FULLY under the steering column so I can't see it, but I could reach underneath and grab it at a moments notice.
primalT is offline   Reply With Quote
The Following User Says Thank You to primalT For This Useful Post:
ftc~brz (04-23-2014)
Old 04-22-2014, 09:58 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Your worried about someone stealing it so you keep it in a lock box, yet the alternative is a holster clipped under the steering wheel? Why not just put a holster under the seat then?
Old 04-22-2014, 10:05 PM   #3
primalT
primalT's Avatar
Drives: 2014 BRZ AT
I'm not as worried about someone stealing it, plus if it's down there they probably wouldn't find it anyway.
I'm 6'6" tall so my seat is all the way down, I can't even fit my hand under the seat so it can't go there either. The only way I get the lockbox down there is by sliding the seat forward and putting it down there from behind.
It's a decent sized gun too. Medium. Glock 19 gen 4
Creole (04-24-2014)
Old 04-22-2014, 10:24 PM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Wow...this is certainly a unique thread
The Following 16 Users Say Thank You to SkAsphalt For This Useful Post:
BeRZed (04-23-2014), cjsporl1996 (04-23-2014), Creole (04-24-2014), djdnz (05-07-2014), ftc~brz (04-23-2014), gzpermadi (04-23-2014), Josue Cafe FR-S (09-01-2015), mkiisupra (05-14-2014), MrAmalto (05-09-2014), Octoman (07-05-2014), OjiGeorge (05-15-2014), PNW FRS (04-22-2014), Pseud0logik (04-23-2014), racecat (04-23-2014), Squishy86 (04-29-2014), VTR (04-23-2014)
Old 04-22-2014, 10:28 PM   #5
boonFRS
Drives: 2013 Scion FRS whiteout
Subbed. Maybe have a fabricator make you something like what they did in the Expendables.
boonFRS is offline   Reply With Quote
Old 04-22-2014, 10:32 PM   #6
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
Not an expert in gun holster/compartment..
but if you are 6-6 and have your seat all the way, why not think about putting it on the passenger side?
You probably have a long arm, and you do not have to push passenger seat all the way back either.
maybe between passenger seat and center console?
right behind the passenger seat?
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 04-22-2014, 10:33 PM   #7
Chimera
Drives: FRS
how about behind the dash trim on the passenger side?
there's a surprising amount of blank space there.
Old 04-22-2014, 10:35 PM   #8
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
If you must feel like you need a side arm with you at all times, why would you ever leave it in a car? Locks will be useless if your car gets stolen.
I have a CCW permit as well btw.
The Following 5 Users Say Thank You to Turbo95eg6 For This Useful Post:
Boxer486 (04-23-2014), civicdrivr (05-19-2014), ftc~brz (04-23-2014), Murseman27 (04-24-2014), StormMcCloud (05-13-2014)
Old 04-22-2014, 10:41 PM   #9
speedrye
Drives: White
Are you left-handed or right-handed, and how accessible does it need to be? Something good for a quick draw, or something accessible, but not in a hurry?
speedrye is offline   Reply With Quote
Old 04-22-2014, 10:49 PM   #10
s2d4
s2d4's Avatar
why would you need a gun in your car?
The Following 16 Users Say Thank You to s2d4 For This Useful Post:
BeRZed (04-23-2014), Churg (05-07-2014), cjsporl1996 (04-23-2014), cmspooner (05-16-2014), fuddbutter (04-23-2014), gzpermadi (04-23-2014), headlikeahole (04-23-2014), JustBoostin (04-23-2014), Murseman27 (04-24-2014), Octoman (07-05-2014), Pizzman (04-22-2014), Scaldy (04-24-2014), SkAsphalt (04-22-2014), stock (05-07-2014), Superhatch (04-23-2014), wparsons (04-23-2014)
Old 04-22-2014, 10:51 PM   #11
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I will try and get pictures tomorrow but I use a pretty vanilla kydex paddle holster clipped over the lower plastic under the steering column much like in the picture above. Its actually the holster that comes with springfield xdms. It stays there while I'm driving since its very uncomfortable to carry a 5.25 inch barreled firearm in these seats. I then transfer it to my holster for carry when I leave the vehicle or if I'm going somewhere its unlawful to carry I put it between the driverside seat and the door. Not in the door cup holder thingy literally next to the seat. Its deep enough that you cant see it at all with the door closed.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 04-22-2014, 10:53 PM   #12
nelsmar
In the OP's defense... Post offices for one do not have regulated lock boxes and you are not permitted even with a CCW to cary inside. In some states you have special requirements (such as the OP) so as there are no lock boxes at the post office and you cant carry you have to drive home and drop it off. I have this problem on my motorcycle... No where to store it. Luckily AZ law doesn't have anything crazy for storing in a car.
My flickr - Canibeat
Local magazine scout
The Following 3 Users Say Thank You to nelsmar For This Useful Post:
Boxer486 (04-23-2014), disgruntld (04-23-2014), SirBrass (04-23-2014)
Old 04-22-2014, 10:55 PM   #13
Reaper
Reaper's Avatar
Drives: violent
If you dont mind drilling blackhawk serpa holsters come with diffrent attachment mounts and you could mount one on the passanger side of the shifter/center console area. That's where my garage door thingy is Velcrod
Old 04-22-2014, 10:58 PM   #14
Reaper
Reaper's Avatar
Drives: violent
I carry everday and the car holsters purpose is its just plain uncomfortable to wear your firearm in these seats. But as far as unauthorized carry locations and needing to store it while going into a school or federal building check out how much room is next to the seat and the doorsill. My xdm5.25 and spare mags fit there.
'murica, bieber, fuckyeah, glove box, gun, handgun, holster
Conceal Carry and HandGun Thread Xdragonxb0i Off-Topic Lounge [WARNING: NO POLITICS] 117 03-24-2014 02:07 PM
Blind spot? euroshowoff Scion FR-S / Toyota 86 GT86 General Forum 47 12-28-2013 04:38 PM
Can you spot the BRZ or GT86? hanabie BRZ First-Gen (2012+) — General Topics 11 08-23-2013 07:08 PM
Where can I secure my handgun while in transit? speedy racer Scion FR-S / Toyota 86 GT86 General Forum 40 08-09-2012 11:42 PM
Toyota hiding easter egg on BRZ JDLM BRZ First-Gen (2012+) — General Topics 38 12-08-2011 10:24 AM
