Old 04-22-2014, 06:06 PM   #1
qqzj
Drives: MDX, Camry
Any consensus on best manual transmission fluid choice?
I have seen so many names mentioned, like Motul, Redline, Amsoil, Pentosin, MTL etc. This is too much information for a layman like me to digest. So if anybody can briefly summarize the pro and con, it would help a lot. If you can pick one for me, it would be even better.
I live in NorCal, where it never gets too cold. So I do not care too much about trans. performance in extremely cold days. What I want is
(1) Make the shift buttery smooth.
(2) Stick to the manual. I remember the manual calls for a 70w-90 and GL4. Here is what I do not understand. Which is more important? 70w-90 or GL4? If I use a 70w-80, but GL4, am I out of warranty? Similarly, if I use a 70w-90, GL5, am I out of warranty?
Many thanks.
qqzj is offline   Reply With Quote
Old 04-22-2014, 07:54 PM   #2
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
I'm curious about amsoil.... Going to sign up for their wholesale program.
In for answers. I know this has been discussed a ton.
Brahsbrah is offline   Reply With Quote
Old 04-22-2014, 08:04 PM   #3
White64Goat
Seriously...........search the Engine, Exhaust, Transmission forum for all that's been posted about oils for tranny. There's plenty there............
Old 04-22-2014, 08:41 PM   #4
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
GL4 is required for the Trans, if you put GL5 in you will ruin your synchos.
Motul Gear 300 is GL4 and GL5 rated so it's good for both the rear diffy and the trans.
We've used Amsoil and Motul for years and both are great products having put them in 1000s of subies over the past 12+ years.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 04-23-2014, 12:19 AM   #5
JB86'd
JB86'd's Avatar
Drives: JAWS
It's actually 75-90. Like many others on this forum I have Motul 300 in my tranny and diff, feels great. 3 little things that made me choose Motul: You can buy 4 bottles and fill both the trans and diff because they take 3.5 combined. The bottle has a spout so no need for a fluid pump. It satisies the OEM weight specifications. T
Old 04-23-2014, 09:43 AM   #6
Brahsbrah
-Mike Paisan
Just to confirm; Amsoil cannot be used in both the diff and tranny?
Old 04-23-2014, 10:35 AM   #7
White64Goat
Check this: http://www.mobiloil.com/USA-English/..._Gear_Oil.aspx
Old 04-23-2014, 10:53 AM   #8
AZP Installs
Amsoil can be used but you need 2 different fluids. A GL4 for Trans and GL5 for rear Diffy.
Mike
Old 04-23-2014, 11:46 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
In general, Motul 300 GEAR is one of the top choices if not the top.
Can't go wrong.
Old 04-24-2014, 12:06 PM   #10
bunkrd
rebmeM
Drives: `13 BRZ LT SWP
Just changed to motul 300 last night in both the diff and tranny (22.5kmi), wish I did it the first week I had the car. The loud lurch/clunk sound is gone when shifting gears, gears shift much smoother and quicker, cold start crunch is gone no longer have to N blip shift in the morning (yes, still have 20 degree mornings in CNY), I can't be happier, got 4 bottles for $85 online. Didn't buy the crush washers, just cleaned the ones on there and flipped them over, going to replace them next change. Plus, the motul bottles make it damn easy to pump the new fluid into each without having to buy or use anything separate.
bunkrd is offline   Reply With Quote
Old 04-25-2014, 03:54 AM   #11
MagicBobert
MagicBobert's Avatar
Drives: 2014 WRB BRZ Limited
Same as the others. Just put Motul Gear 300 in my trans and diff and am very, very happy with it. Shifting is buttery smooth until it firmly clicks into gear.
The awesomeness of the bottles cannot be overstated. The pull-out spout built into the bottle cap makes filling both the diff and trans easy without a fluid pump.
MagicBobert is offline   Reply With Quote
Old 04-25-2014, 04:17 AM   #12
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Motul 300 is great I suspect if you live where it's warm. From consistent praise from those who have steady warm climates. However where I live or anywhere that is really cool in mornings Motul 300 is no better then factory fill and oddly enough for me it was worse. Shifting felt like crap and I went to MTF2 Pentosin and like a whole new tranny just smooth.
Old 04-25-2014, 07:22 AM   #13
AZP Installs
By the way guys, we can drop ship Motul Gear 300 to you if you want to help support folks who support this forum.
I believe for the BRZ/FRS it's $80 shipped for what you need for the Trans and Rear Diffy.
-mike
Old 04-25-2014, 07:23 AM   #14
AZP Installs
Odd, we were real cold here this winter (20s all winter long) and none of our 20-30 BRZ/FRS customers complained.
It must be REAL cold where you are.
-mike
Change your manual transmission fluid ASAP!!! Kostamojen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 383 12-12-2016 09:29 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Is the manual transmission a good choice for an everyday driver? shishand Scion FR-S / Toyota 86 GT86 General Forum 54 09-03-2012 04:10 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
