Old 04-21-2014, 07:27 PM   #1
phrosty
Tuning for new wheel diameter?
Are speed calculations done via the ECU? Is it possible to specify a new wheel radius to fix mph with larger wheels?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 04-22-2014, 11:51 AM   #2
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
My radar does gps based speed and I'm off running 225/40 & 255/35 18s. Just slightly at 70 or faster. Maybe 1 or 2 mph up to around 80. When I go faster, it's not something I keep an eye on.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
Old 04-22-2014, 12:11 PM   #3
wparsons
wparsons's Avatar
Depending on the size of wheel/tire you want, there's probably no need for correction. Like ^^ said it'll still be really close. My 225/45/17's are dead on based on GPS speed on a straight road.
flickr
Old 04-22-2014, 12:27 PM   #4
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
This is something I have wondered about myself. The only compensation I have seen is for the calculated gear based on Engine RPM compared to revolutions per mile. I don't believe it effects how the speedometer reads.
Edit: This interests me more for higher HP builds that can benefit from a larger diameter tire.
Luckrider is offline   Reply With Quote
Old 04-22-2014, 01:00 PM   #5
phrosty
Yea, I realize it's only a tiny discrepancy and doesn't bother me much, I was just curious if it was possible. Why have any error if it's possible to get rid of it?
Old 04-22-2014, 01:59 PM   #6
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
The ecu doesn't do the calculation. Its done within the transmission.
Ranatsu is offline   Reply With Quote
Old 04-22-2014, 02:27 PM   #7
wparsons
wparsons's Avatar
It will definitely affect the speedo.
No, it's 100% the ECU. There's actually no sensor in the transmission or rear end at all, the ECU uses the wheel speed sensors (ABS/TC/VSC) to calculate the vehicle speed. This is why changing the final drive doesn't affect the speedo at all, only a change in tire diameter will affect it.
flickr
Old 04-22-2014, 02:32 PM   #8
Luckrider
Luckrider's Avatar
I knew that the speed was calculated using the ABS sensors but I was/am not sure that the ECU uses the same table as the gear calculator to calculate speed. I might play with it on mine and if that is the case, I will adjust mine to compensate for the 245/40R17s that are on mine right now just for the hell of it.
Old 04-22-2014, 02:46 PM   #9
Ranatsu
Cone basher
News to me, Subaru has always used a gear within the transmission.
Old 05-11-2014, 04:13 PM   #10
350matt
Drives: toyota mr2/ Toyota GT86
you can set the gear ratios within ECUtek so ostensibly you can change the speedo reading with this
can't you?
350matt is offline   Reply With Quote
Old 05-11-2014, 05:17 PM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
can't you?
The gear ratios are just so the ECU knows which gear you are in. Speed is done by wheel speed sensors, although I'm sure there is a multiplier in the ECU somewhere.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-11-2014, 07:23 PM   #12
brn12345
brn12345's Avatar
You would want to use the Toyota Techstream software. It allows you to adjust speedo error by percentage. If you have a Tactrix cable you can install the Techstream software and do the changes yourself.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 05-12-2014, 01:26 AM   #13
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
No need to recalculate. That tire ratio is near identical to stock.
Grymm86 is offline   Reply With Quote
Old 05-12-2014, 01:59 AM   #14
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Correct I'm in 245/40/17 and my speedo is not even 1mph off.
Wheel Services at R/T Tuning R/T Tuning Wheels and Tires 13 04-30-2014 03:13 PM
Free wheel mounting and balancing at R/T Tuning! R/T Tuning Wheels and Tires 1 01-07-2014 01:33 PM
Decreasing Wheel diameter while increasing the width BlackMagicSir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-01-2013 09:58 AM
Wheel Directory: HD Tuning Gear 18x7.5 +35 / 18x9.0 +40 naikaidriver Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 07-02-2013 02:23 AM
Wheel gap - from suspension height or tire diameter? CaptainSlow Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-27-2013 12:48 PM
