Old 04-20-2014, 07:03 AM   #1
pepe
Drives: gt86
inch escape: effects
Hello! I have a question. Using a 3 inch exhaust (70mm) in our car, if you think about putting a turbocharger, is silly, it is a mistake? lose power at low revs?
pepe is offline   Reply With Quote
Old 04-20-2014, 07:09 AM   #2
Ponwh
Drives: 4 wheels
what?
Ponwh is offline   Reply With Quote
Old 04-20-2014, 07:24 AM   #3
pepe
Drives: gt86
you do not understand the question?
Old 04-20-2014, 07:26 AM   #4
Muskokan
Drives: white Sport-tech
huh?
to my understanding, 3' is prefered for turbo set ups.
Muskokan is offline   Reply With Quote
Old 04-20-2014, 07:26 AM   #5
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
A 3" exhaust on a naturally aspirated car produces a ton of noise but no significant power difference over 2.5".
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 04-20-2014, 07:38 AM   #6
pepe
Drives: gt86
there is no loss of power at low revs for using a diameter of 3 "?
Old 04-20-2014, 08:15 AM   #7
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Maybe NA but a turbo is a turbo and it's going to have lag regardless. It will increase power up top NA or boosted though as it allows more airflow which is required for high rpm.
Old 04-20-2014, 09:01 AM   #8
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
It was probably in response to your thread title.
Old 04-20-2014, 01:15 PM   #9
humfrz
Hello pepe .....
It's my understanding that if you plan on installing a turbo, your car would benefit from a 3" exhaust.
If you are not going to turbo, the 2.5" exhaust would be sufficient.
If you now are NA, but plan on going turbo in the future, a 3" exhaust will not significantly reduce the NA performance. However, it may be relatively LOUD.
humfrz
Changing camber. Effects on toe? FReSh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-28-2014 12:51 AM
Effects of LED module OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 1 04-06-2014 04:15 AM
effects of elevation StormTrooper Engine, Exhaust, Transmission 1 01-27-2014 12:26 AM
250 ~ 300 hp - Cost, Requirements, Effects Froylavin Engine, Exhaust, Transmission 14 07-19-2012 12:55 AM
The Great Fan Escape: The Fan Who Got Away tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 2 05-28-2011 04:44 AM
