CANADA Canada
Old 04-20-2014, 01:09 AM   #1
Trac Toy
Trac Toy's Avatar
DDT lapping Sunday April 20. Mosport.
Anyone else going to this today? I realize it's early but should still be fun.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 04-20-2014, 08:13 AM   #2
wparsons
wparsons's Avatar
With Touge? If I wasn't installing springs I might check it out.
flickr
Old 04-20-2014, 08:14 AM   #3
Trac Toy
Trac Toy's Avatar
Springs only takes an hour... Lol
.o0+Eric+0o.
2013 FRS 6MT
Old 04-20-2014, 12:51 PM   #4
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Damn! In at work and only 10 mins away, wish I knew about this earlier
Gords_zenith is offline   Reply With Quote
Old 04-20-2014, 05:48 PM   #5
wparsons
wparsons's Avatar
Not when your Scion decides to show it's inner Subaru! Ugh.
One snapped stud and both front sway bar end links are totally seized on, fun day!
Tomorrow's mission, find a place to cut off the links and pop in a new stud.
flickr
Old 04-20-2014, 08:28 PM   #6
Jereina
Drives: Scion FR-S
Heat and locking pliers (vise grips) are your best friend
Jereina is offline   Reply With Quote
Old 04-20-2014, 08:47 PM   #7
wparsons
wparsons's Avatar
Yeah, gonna try to borrow a sawzall as a backup, but heat and vicegrips should get them off. I didn't want to get them off today without new parts to go back on, but as soon as I source new links these ones will get the torch or axe
Still gonna find a shop to press out the snapped stud, hopefully I can get in soon. OTA school in two weeks, don't want to leave it down to the wire. Ironically, I was looking at ARP studs at JRP the other day.
flickr
Old 04-20-2014, 08:53 PM   #8
DR 86
DR 86's Avatar
Had a cross threaded stud changing out my summer's this winter. Hammered out stud and pulled in new one using washers and an impact wrench, very easy, much easier than taking out the hub to press stud, since there's a good likelihood the hub will be seized - mine was.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 04-21-2014, 07:49 AM   #9
wparsons
wparsons's Avatar
Can you get the stud out with the hub still on the knuckle? I didn't look close enough, just assumed it wouldn't come out without removing the hub.
flickr
Old 04-21-2014, 10:49 AM   #10
automatic
Drives: WRB BRZ
I did with one of my rear studs...just enough space for the stud to come out at an angle after hammering it out.
automatic is offline   Reply With Quote
Old 04-21-2014, 12:55 PM   #11
wparsons
wparsons's Avatar
How about fronts?
flickr
Old 04-21-2014, 08:38 PM   #12
DR 86
DR 86's Avatar
Yes you can with the fronts.
Old 04-23-2014, 10:31 PM   #13
wparsons
wparsons's Avatar
For future reference, you don't even have to pull the rotor off on the fronts! And even better, the nut from the sway bar endlinks is the right thread (and open ended) to pull the stud in without needing a stack of washers. Took me all of 2 minutes to hammer out the old one and pull the new one in!
flickr
Old 04-24-2014, 12:47 AM   #14
automatic
Drives: WRB BRZ
Its pretty awesome how they designed the car to be so easily worked on. I was also surprised on how easy it was to change the brake pads... on my Mazda 3, the rears would take me forever to do wheras I can do them in less than 5 minutes on the BRZ!
April 20th Sunday Mosport new DDT lapping event 12-5pm, #1 Touge.ca event of 2014! Touge.ca CANADA 0 04-05-2014 06:00 PM
August 18th Sunday-Touge.ca Mosport DDT track event 12:30-5pm #15 of 20+ Events! Touge.ca CANADA 1 08-17-2013 05:25 AM
June 23rd Sunday Mosport DDT lapping event 12:30-5pm, #8 Touge.ca event of 2013! Touge.ca CANADA 3 06-20-2013 11:52 AM
May 19th Sunday Mosport DDT track event 12:30-5pm, #4 of 20+ Touge.ca events 2013!!! Touge.ca CANADA 1 05-14-2013 04:48 AM
Mosport DDT Lapping this Saturday - only 65 dollars! 7thgear CANADA 33 08-20-2012 05:49 PM
