Old 04-18-2014, 10:21 PM   #1
kraizevoodoo
kraizevoodoo's Avatar
Drives:
Fuse or bulb
My front driver side turn signal works when I use my signal but when I turn on my headlights it doesn't come on. Is it a fuse or just a bad bulb? If it is a fuse what size and where is it at. Thanks
Sent from my HTC One using Tapatalk
kraizevoodoo is offline   Reply With Quote
Old 04-18-2014, 11:13 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Bulb. Wouldnt't be fuse if it still light up
Old 04-18-2014, 11:21 PM   #3
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Bulb.
N1rve
Old 04-18-2014, 11:37 PM   #4
kraizevoodoo
Drives:
Thought so but I'm lazy and don't want to make two trips to the store tomorrow
Old 05-15-2014, 10:36 AM   #5
mightythias
Drives: 2013 FR-S 10 Series
I just got the same problem with my driver side turn signal. It will flash when using the signal but it doesn't light up when the headlights are on. Did you have a regular bulb or LED bulb in there?
mightythias is offline   Reply With Quote
Old 05-15-2014, 11:46 AM   #6
jonzhuxD
Drives: Ultramarine FR-S
Sounds like for both of you, the filament in the bulb that's on when the headlights are on is burnt out. (The 7443 bulbs are dual filament)
jonzhuxD is offline   Reply With Quote
Old 05-15-2014, 12:34 PM   #7
mightythias
Well I just replaced my turn signal bulbs with new LEDs from HIDPowerhouse. Hopefully its just a faulty bulb and I can get it replaced
Old 05-15-2014, 01:10 PM   #8
calibrz
Turbo 86
Drives: GT86
change a new bulb.
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 05-15-2014, 01:50 PM   #9
KI_ZN6
KI_ZN6's Avatar
We'll send you a private message and assist you.
KI_ZN6 is offline   Reply With Quote
Old 05-17-2014, 10:39 AM   #10
SubieGuts
SubieGuts's Avatar
Hi guys, I am having this same problem but for both sides. Signals function properly but will not stay on constant with either the parking lights or headlights turned on. I do have Chrome tipped bulbs in there. So, it is possible that the signal flash would still function but the constant would not work at all? The bulbs I bought are only a few months old and from a reputable company. Only other change was that my DRL's were turned off via techstream.
SubieGuts is offline   Reply With Quote
Hot fuse tap - Which fuse? cgrey Electronics | Audio | NAV | Infotainment 9 09-17-2016 07:24 PM
Led strip on parking light T10 bulb? Amperage fuse dssence Cosmetic Modification (Interior/Exterior/Lighting) 32 03-17-2014 02:34 AM
Fuse # to the Fog light's 914_WHITE_FRS Issues | Warranty | Recalls / TSB 3 08-06-2013 03:40 PM
Where to get Fuse Cover? boredom.is.me Electronics | Audio | NAV | Infotainment 2 01-03-2013 12:32 PM
Fuse Location Shadow215 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-21-2012 08:07 PM
